EAGLE User Support (English) Delete a Port of a Module in Eagle V7
  • Answers 2 answers
  • Subscribers 187 subscribers
  • Views 2490 views
I have created a hierarchical schematic with 3 modules.
I defined the ports for each module and I connected the different ports between the modules.
Questions :
- How to move the ports around the border of the module after their creation?
- How to delete a port of a module after its creation?
- How to redefine the port direction after its creation ?
Thank you.
    0 e14 Contributor over 12 years ago in reply to autodeskguest
    Thank you very much for this link.
    So I found the answer for all my questions :
    Q : How to move the ports around the border of the module after their creation?
    A : Select the MOVE tool and :
         - ctrl-left click on PC
         - cmd-left click on Mac
    on the port to Move it
    Q : How to delete a port of a module after its creation?
    A : Select the DELETE tool and :
    on the port to Delete it.
    Q : How to redefine the port direction after its creation ?
    A : Select the INFO tool and :
    on port change its direction.
    Small complement :
    Q : How to resize a module ?
    on the module to Resize it.
    That's all !!!
    0 autodeskguest over 12 years ago
    (SNIP)
    I haven't done anything with modules yet.  (Not sure whether it improves on
    my current workflow since I'm already using multiple page schematics and
    labeled nets.  Now, if the module idea worked for board layout, I'd be
    VERY interested!)  Anyway, check out the video
    http://youtu.be/X7FkzqIGsqU.  I think he used the info command and
    ctrl-left click to show the dialog to change the port direction...
