EAGLE User Support (English) eaglerc.erc where?
  • Replies 19 replies
  • Subscribers 180 subscribers
  • Views 1348 views
eaglerc.erc where?
I can't find eaglerc.usr for version 5.4. I have read the update notes and
searched the specified registry key - nothing. According to the release
notes, another possible location is whatever is specified in a $HOME
variable. Well, I don't have a $HOME variable specified. Perhaps I would
specify one if I knew how but instruction seems absent.
What I need to do is turn off the context menu that pops up when I want to
move a group.
I have eaglerc.usr that was installed under version 416, and I added the
line "Option.ToggleCtrlForGroupSelectionAndContextMenu = "1"".
Naturally, version 5.4 ignores that, and the offending context menu still
inturrupts me. So, now what? I have lived with this irritation for months
and finally I can't stand it any more.
Maybe I should put this in the suggestions group, but why don't you just put
the eaglerc.usr file in the installation or .bin folder, and be done with
it, instead of hiding it either here or there (or NOWHERE)?
    "So, now what? I have lived with this irritation for months
    and finally I can't stand it any more."
    Dude, take a Xanax and chill........
    Shills like you are no help. Bite off.
    "Robert Leavitt" <bb@hotdogdigital.com> wrote in message
    news:gno8vv$u7o$1@cheetah.cadsoft.de...
    "So, now what? I have lived with this irritation for months and finally I
    autodeskguest over 16 years ago in reply to autodeskguest
    When you feel better Brett, maybe you can try to hold down the Control Key
    manually.....I know that it's tough.....
    "Brett Holden" <brettholden@bellsouth.net> wrote in message
    news:gnoa1a$2c0$1@cheetah.cadsoft.de...
    Hello Brett Holden !:
    Maybe you have to use a good file manager nothing from Bill. F.i.
    TotalCommander.
    Look into :
    C:\Documents and Settings\User_Name\Application data\CadSoft\EAGLE\
    or similar (This is from XP).
    And don't panic use good tols instead :-D !
    HTH
    Grzegorz Zalot
    complex ltd.
    office tel/fax : +48 32 2505840
    mobil : +48 501 301515
    and searched the specified registry key - nothing. According to the
    release notes, another possible location is whatever is specified in a
    $HOME variable. Well, I don't have a $HOME variable specified. Perhaps
    I would specify one if I knew how but instruction seems absent.
    TotalCommander.
    Look into :
    HTH
    It even goes with Bill, just open windows explorer klick search and put
    in the name. You'll get all the path with eaglerc.. image
    Gruß / regards
    Jörn
    Hello Joern Paschedag !:
    If not hidden ..... :-\  This is Bill's tool !!!!
    regards
    Grzegorz Zalot
    complex ltd.
    Search. I tried that. All I got was from ver4, nothing from ver5.
    "Joern Paschedag" <jpaschedag@t-online.de> wrote in message
    news:gnrc55$o90$1@cheetah.cadsoft.de...
    $HOME variable. Well, I don't have a $HOME variable specified. Perhaps I
    TotalCommander.
    Look into :
    HTH
    It even goes with Bill, just open windows explorer klick search and put in
    Gruß / regards
    Jörn
    Thank you Grzegorz Zalot. It took me a little bit of hunting before I found
    the "correct" identity.
    That is a hidden folder, why it would not get found doing a "Search". Looks
    like I am in business!!!
    I will repeat my plea from the original post:
    "why don't you just put the eaglerc.usr file in the installation or .bin
    it, instead of hiding it..."
    eaglerc.usr WAS hidden.
    Now, I can edit  the file to eliminate the annoying, useless context menu.
    Thanks again.
    Grzegorz Zalot" <complex@alpha.pl> wrote in message
    news:49A0342C.5060901@alpha.pl...
    TotalCommander.
    Look into :
    HTH
    Grzegorz Zalot
    complex ltd.
    You got that right! Problem solved.
    "Grzegorz Zalot" <complex@alpha.pl> wrote in message
    news:gnrt9o$vun$1@cheetah.cadsoft.de...
    regards
    Grzegorz Zalot
    complex ltd.
    Thanks to all who helped me on this. Eaglerc.usr is installed in a hidden
    folder under one of the several identities on my PC. I have made a shortcut
    to the file in a more accessable location.
    To eliminate the popup menu I thought I could add the following line to
    eaglerc.usr.
    "SET Option.ToggleCtrlForGroupSelectionAndContextMenu = "1""
    So, after spending a few hours trying to undo a so-called improvement in
    Eagle5, well, the context menu changes is still there. The fix did not work.
    I cannot appreciate that after grouping and right clicking the move button,
    I must then choose between a list of options, some of which don't work
    anyway. It's STUPID, but that is only my opinion.
    But, what about this: How am I going to mitre a group? How will I name a
    group? Split, or optimize a group?? The list goes on and on. Move is near
    the bottom of the list. GIVE ME A BREAK.
    Why is it even called a context menu? Most options are out of context with
    my previous mouse-clicks.
    (Where's that Xanax?)
