EAGLE User Support (English) How to re-order layers? How to re-order sheets?
  • Views 747 views
  • re-order
  • sheets
  • layers
Joop14
Joop14 over 12 years ago
Hello all,
In a finished multi-layer project, I would like to change the order of some layers.
For example, in a 4-layer board, is it possible to exchange inner layer 2 with inner layer 3?
Also, is it possible to re-order the sheets of a schematic that contains multiple sheets?
Best Regards,
Joop
  • Joop14
    0 Joop14 over 11 years ago in reply to autodeskguest
    Joop
    0 autodeskguest over 12 years ago
    some layers.
    you can select all tracks in a layer and apply the "change layer"
    command to the group.
    Swapping two layer will require an additional (temporary) layer so you
    can do 1->tmp, 2->1, tmp->2
    multiple sheets?
    drag and drop the sheet thumbnails
    Lorenz
