EAGLE User Support (English) Moving components from one sch sheet to another
  • Subscribers 179 subscribers
  • Views 978 views
I want to move (not cut and paste) components with named wire stubs
attached to them from sheet one to sheet two of the schematic editor.
The names of the net stubs shall not change!
I don't know how.
Anybody can suggest a solution?
Paolo
  • Richard_H
    Richard_H over 16 years ago
    I don't know how.
    Paolo
    Select the objects you want to move with GROUP, then MOVE and
    Ctrl+right mouse click. The group follows the mouse now.
    Click onto the preview of the "target" sheet, EAGLE switches
    to this one, now place the group.
    Richard Hammerl
    I don't know how.
    Paolo
    I am using Eagle 4.16: no sheet preview. Clicking on the sheet number
    releases the object, so no move to the target sheet...
    Is there a way out?
  • firatkocak
    firatkocak over 16 years ago
    Group select the parts in the sheet. Click the CUT item in the Edit
    menu. And then left click in the current sheet for defining a reference
    point ( if you don't do this, the selection will be ignored ). Go to the
    required sheet and click past item in the Edit menu. Now you can see the
    selected group in the current sheet. Click left mouse button when the
    mouse is over the place where you want it to be placed.
    firat,
    PCe yazm?s,:
    I don't know how.
    Paolo
    Is there a way out?
