EAGLE User Support (English) No .Lox when using gerb274x.cam
  • Subscribers 177 subscribers
  • Views 280 views
I'm trying to generate a gerber files using the gerb274x.cam script. The tool opens in the 3 CAM processor a GUI with five TABS (component side, solder side, silk screen CMP, solder stop mask CMP and Solder stop mask SOL) I think it should add more tabs for the inner layers.
When I'm hitting Process Jobs it does not generate .Lox files.
Any Idea??
    On 26/09/14 07:59, golas laslas wrote:
    Any Idea??
    File extensions for Gerber files have never been standardized. The .Lox
    that you expect is just somebody's personal (or possibly corporate)
    choice, and happens to be different from CadSoft's default.
    The gerb274x CAM job is for two-layer boards and has rather odd file
    extensions (.cmp for top copper and .sol for bottom). It is permissible
    - indeed, practically expected - that you will edit the CAM job to at
    least produce the file names you prefer. My version contains more
    sections because we usually include a bottom side silk screen, for example.
    HTH
    Rob
