EAGLE User Support (English) Editing pad sizes, modifying them and saving to library?  How to do this properly and recover from doing it poorly?
  • Subscribers 186 subscribers
  • Views 259 views
  • editing
  • pad
  • modifying
  • saving
  • to
  • existing
  • package
  • sizes
  • library
  • packages
Hello Everyone,
I have been making a small, (top and bottom copper only) board.  Using the "iron the toner from the paper onto the copper" method.
I have the challenge of working with version 6.4.0 at the shop and version 7.1.0 (probably) at home.
(The shop version has autorouter, my home version does not.)
I am wondering about modifying the pad layout and dimensions.  ( I don't have a full set of tiny drills...  0.040" and 0.020"  are about it.)   How should this be done?  I tried, but did not get sit right.  See below.
The default size for R-US_0207/7 (R-US_) is a 0.031 hole and a rather small pad diameter maybe 0.040 or 0.050 inches with a pin spacing of 7.5 mm.
I modified on my home computer and made the pad bigger, and answered a query about it and now it it is bigger, like 0.070 inches.  The trouble is, I have modified all the pads on the board AND changed the library definition.
The software at the shop doesn't recognize this modification. I did the modification by clicking on a resistor, selecting "open package" in the menu and modifying a R-US_0207/7  package to have a different pad diameter.
I had a couple attempts at this and so I am not sure what I did.  The end result is the device name is the same but I have changed the package name and dimension. I have not saved the mod to a new library part.
How can I get back the original package?  How can I properly edit, modify and save a new package to the library?
Screen shots are from the software at the shop, the older 6.4.0 version...
This message #01 , with 4 resistors with the bigger pad.
and message #02
The way the library looks now is this.  ( I modified the name of the 0207/07 package, obviously.)  message #03
I just learned how to load libraries when starting EAGLE up, so I am a rank beginner.  A step by step, with no jargon is where I am at.....
Thank you all very much!
Sandy Roman
