EAGLE User Support (English) How to globally show hidden air wires in eagle 6.5.0?
  • Subscribers 189 subscribers
  • Views 2628 views
rickford66
rickford66 over 12 years ago
How would I go about changing the status of all hidden air wires to shown?  Thanks.
  • martenjacobs
    0 martenjacobs over 10 years ago
    RATSNEST *
    works for me
    0 autodeskguest over 12 years ago in reply to rickford66
    rickford66 wrote:
    I'm referring to air wires on the PCB.
    I know.
    But how do you unhide a net without knowing its name?
    You go to into the schematic and look it up, then switch back to the
    board editor and issue the "ratsnest netname" command from the command
    line.
    That's what the ulp is for: go to the schematic, group the net or nets
    you want and run the ulp; preferably using a hotkey. for single nets
    it might even work added to the right-click context menu.
    Lorenz
  • rickford66
    0 rickford66 over 12 years ago in reply to autodeskguest
    shown?  Thanks.
    I wrote the following ulp to be able to unhide selected nets from the
    schematic
    #usage "<b>unhide airwires for nets grouped in schematic</b><p>"
            "intended usage: run from command line or assign to hotkey<p>"
            "THIS PROGRAM IS PROVIDED AS IS AND WITHOUT WARRANTY OF ANY KIND, EXPRESSED OR IMPLIED<p>"
            "<table cellspacing=0 cellpadding=5 border=1>"
              "<tr><td align=center>Version</td>"
                     "<td align=center>Date</td>"
                       "<td align=center>Author</td>"
                         "<td align=center>Comment</td></tr>"
              "<tr><td align=center>1.0</td>"
                     "<td align=center>2012-11-22</td>"
                       "<td align=center>lorenznl@yahoo.com</td>"
                         "<td>initial version</td></tr>"
            "</table>"
    if (schematic) {
       string s = "";
       schematic(SCH)
         SCH.sheets(SHE)
           SHE.nets(NET) {
             if (ingroup(NET))
               s += " " + NET.name;
       if (s != "") {
         exit("edit .brd; ratsnest" + s + ";");
    Lorenz
  • rickford66
    Thanks.
    see HELP > RATSNEST
    HTH
    Warren
