EAGLE User Support (English) Re: Eagle Library for TE 5747193-2 DSub Connector?
  • Subscribers 178 subscribers
  • Views 510 views
  • eagle_library
I am using the TE 5747193-2 50-pin RA DSUB connector in my current design. The Tyco EAGLE library at Element14 does not include a symbol for that part.
Is there an Eagle-compatible library symbol I can use for that part?
    for that part.
    Is it different from the one in con-subd.lbr from the base install?
    Aha - yes, thank you! I was searching by part number in the Tyco symbols. I believe the M50HP is the matching symbol. Who do I contact to add a Farnell or Newark number to the library? That would make it possible for other people to find it by part number.
    Thank you again!
    Cameron Jones
