EAGLE User Support (English) Stop Mask Errors from Auto-Router
  • Subscribers 177 subscribers
  • Views 338 views
  • mask
  • eagle
  • errors
  • stop
See attached.
The auto-router glibly places vias under markings on the tPlace and tNames and tValues layers.
The result is a bazillion (or in my case 143) Stop Mask Errors.
Do I ignore them? Am I doing something wrong? How would I correct them?
Thanks in advance.
Cameron Jones
Synclavier Digital
    On 08/10/14 21:40, Cameron Jones wrote:
    See attached.
    The layers you mention are all silkscreen only and not important to the
    function of the board, so I'm not surprised the autorouter prioritises
    achieving the routing over avoiding their contents.
    It is common practice to mask out the silkscreen for any such instances,
    leaving gaps in the markings. If you want to avoid that, you will need
    to hand-tweak the placement of vias and silkscreen elements. In most
    cases, tValues wouldn't be included anyway, so you can ignore that.
    I believe the DRC doesn't flag low criticality errors like this if the
    relevant layers are not shown when it's run. So you can either run the
    DRC with tPlace, tNames and tValues hidden, or you can review and
    approve all the errors.
    HTH,
    Rob
