EAGLE User Support (English) ULP : pin.net availability in schematic?
  • Subscribers 178 subscribers
  • Views 382 views
Im doing this ULP to get a list of pin->net connection out of the schematic.
Im accessing the Pins through
schematic->parts->device/deviceset->gates->pins and the pin.net always gives
an empty string.
What am I doing wrong?
  • kcadsoft
    kcadsoft over 16 years ago
    an empty string.
    You need to go through
      schematic->sheets->parts->instances->gate->symbol->pins
    in order to access the net names connected to each pin.
    Klaus Schmidinger
    Hofmark 2                               Email:   kls@cadsoft.de
    "Klaus Schmidinger" <Klaus.Schmidinger@cadsoft.de> wrote in message
    news:gptd51$5rn$1@cheetah.cadsoft.de...
    schematic.
    gives
    an empty string.
    Thanks, that worked. image
    ...but the pin.contact boolean check mentioned in the help doesnt seem to
    work from that end.. But thats not a big problem as I can check the name for
    an empty sting.
  • kcadsoft
    an empty sting.
    Seems to work just fine here.
    Can you send me an example where it doesn't work?
    Klaus Schmidinger
    autodeskguest over 16 years ago in reply to kcadsoft
    Im sending you my ULP on email.
    news:gpthnn$q4j$1@cheetah.cadsoft.de...
    for
    an empty sting.
