EAGLE User Support (English) Inconsistency between sch and pcb
  • Subscribers 179 subscribers
  • Views 430 views
martinph
martinph over 11 years ago
Hi all,
As a new user to Eagle 7 i've started with a small schematic to make my own pcb.
Drawing a schematic was very easy for me.
After quite a few efforts (reading Help and this forum) I finally got rid of the "No supply pins for........."  errors.
Then I switched to the pcb - moved the parts into place and ran the autorouter (medium level).
To my surprise, both ic's do not have their power pins connected.
Am I doing something wrong? Or are there some kind of rules which I did not follow?
See attached both .sch and .brd.
Awaiting a reply,
Regards, Martin.
MMDec2.zip
    Help invoke?
    r
  • martinph
    0 martinph over 11 years ago in reply to Former Member
    You call that a solution?
    Tell me: what search words do I have to use?
    Martin.
    0 autodeskguest over 11 years ago in reply to martinph
    In a word, yes.  image  Have you tried actually typing "help invoke" in
    EAGLE?
    Step by step hand holding:
    type "invoke" or click the invoke icon (right next to the split icon)
    click on the first IC choose the appropriate pin and place it somewhere on
    your schematic repeat for all required pins repeat for all ICs add power
    and ground connections to schematic along with headers, regulators, etc
    connect as appropriate switch to board and route traces, creating
    polygon(s) as needed
    (It's the middle of the night, so I may not be completely coherent.
    Hopefully, that's good enough to give you the general idea...)
    Doug
  • martinph
    0 martinph over 11 years ago in reply to autodeskguest
    Sorry for my first reaction - I did not understand the word "invoke" (me being a dutch guy)
    Applied the invoke function - after a few minutes all power lines are now connected.
    PCB is now ready to be made.
    Thanks.
    Martin.
