EAGLE User Support (English) Advanced Circuits FreeDFM solder mask problem
  • Subscribers 187 subscribers
  • Views 620 views
http://www.4pcb.com/
I tried the link for their FreeDFM board check with my Eagle designs.   I
seem to always get solder mask clearance errors when I send them all the
gerber files made with gerber 274x.   I even played with changing the
clearance of the masks in DFM and it doesn't change the errors I get.
I called and talked to Adv Circuits and they said it looks like it would be
OK.  I ordered a board and of course it ended up on Cam hold.   Again on the
phone they are no help with missing solder mask stuff on that layer.    I
have loaded the gerber files into ViewMate and they look OK to me there as
well as in Eagle.
I'm stuck and don't know how to fix this problem.   Any suggestions please?
-Dave
    well as in Eagle.
    -Dave
    Here is what advanced circuits has for their solder mask requirement:
    1. Soldermask Swell
    This is the expansion of mask relief over pad area. Our minimum is
    0.005" over pad dimension or 0.0025" each side. Advanced Circuits will
    modify files to meet the minimum dimension.
    Here are a few things that you may or may not have already done to find
    the source of the error.
    1.  I think Eagle uses a default of .004" with a max of .020".  Change
    the DRC to .005" minimum.  Shouldn't matter, but for grins it's a place
    to start.
    2. Make sure layers 29 and 30 are enabled, and then run the DRC to see
    if you get any errors.
    3. If you get an error try turning of the place, value & name layers to
    see if the silk screen is interfering with the solder mask.  A lot of
    the EAGLE library parts don't take this into account.  This may be why
    advanced Circuits is kicking back your board.
    Cheers,
    EAGLE USER
