EAGLE User Support (English) Excellon output
  • Views 447 views
Excellon output
After 2 days of learning the freemium version I cannot get the Execllon output to reconcile with the Gerber output.  The coordinates are way out whack on my own circuits and the examples.  All the Gerber output files are fine, just the Excellon Drill outputs.  If I'm going to spend $1600 for the pro version I would like to know if these kind of problems and be solved quickly... otherwise it's a deal-breaker
    0 e14 Contributor over 11 years ago in reply to autodeskguest
    Whew.  Upgraded  my Viewmate Gerber viewer.  Problem solved after setting options to "All Digits present".  Thanks
    http://www.element14.com/community/message/128934
    Most of the time it is an issue with your viewer not extracting the
    equivalent of the decimal point correctly on the drill's.
    Use a different gerber viewer.
    http://gerbv.geda-project.org/ works under Linux
    Or
    upload the files or a test project files to here.
    https://www.my4pcb.com/net35/FreeDFMNet/FreeDFMHome.aspx
