EAGLE User Support (English) Pcb sides etched wrong
  • Subscribers 178 subscribers
  • Views 506 views
Hi all,
I am trying to build a pcb with a cnc router but the sides of my pcb are not orientated correctly. When I etch my board in the machine, the bottom side looks exactly like the one on the screen but the top side (with an atmega 328p-au) is mirrored or whatever. The holes do line up but to solder the atmega correctly I would have to flip it facing upwards and not touching the pads. I tried mirroring the entire board but with no success. Any ideas why this happens and how I can solve it ?
Any help is greatly appreciated!!
Thanks in advance,
Alex
    "Alex Poupakis"  skrev i nyhetsmeldingen:
    1385926681.371414068950451.JavaMail.jive@flcspu-csapp-01.premierfarnell.com
    Sounds like your library is drawn wrong, or both sides are mirrored.
    Some images from your design would help clarify the issue.
    0 autodeskguest over 11 years ago in reply to autodeskguest
    Actually it sounds like the cnc process is mirrored. What Eagle shows
    "on the screen" is always a view from the top of the board, showing the
    bottom layer "through" the board. So if your bottom side looks like the
    screen, it's backwards.
    0 Former Member over 11 years ago in reply to autodeskguest
    Well I figured that out and to solve it for the bottom side I selected the mirror checkbox on the pcb-gcode-setup and for the top side I mirrored it on the screeen and then selected mirror in the setup as well. So both sides were mirrored outputing a correct board  ! Every component is now touching the correct pads !!
    Thank you for your replies,
    Alex
