EAGLE User Support (English) Moving parts after autorouter?
  • Subscribers 187 subscribers
  • Views 389 views
eagle86951
eagle86951 over 11 years ago
Is there an easy/auto way to move a part once all the traces are routed?  Do I have to rip up the traces to that part and manually re-route?  When I try to move the part with the traces still attached, the traces end up all kinked and crooked....
    Hi Tom,
    I hope you're doing well. Generally, is not a good idea to move stuff
    around once everything has been routed, for the reasons you've already
    observed.
    If you move a part with the traces connected everything will kink as
    you've seen. If you anticipate lots of movement, then ripup the
    necessary traces and when your done you can manually route or autoroute.
    hth,
    Jorge Garcia
