EAGLE User Support (English) Rectangle opaque in printout - how do I stop this?
  • Subscribers 178 subscribers
  • Views 236 views
When I make assembly sheets for hand assembled surface mount boards I like
to create a whole series of layer on the brd drawing, one layer for each
component value.  I then place rectangles over the parts that have that
value.   For example, I will have a 100pF layer, and I will put a rectangle
of 100pF layer over each 100pF capacitor on the board.    Each part type has
a different color and or stipple pattern.   I then print this out on my ink
jet and go build the board.   This worked fine in version 4 of eagle, but in
version 5 (I am using 5.4.0) the printout always makes the rectangles opaque
and it covers the part name/value/outline.   This is true for any fill
pattern, except the empty/non filled, fill pattern.    I do not have the
solid option checked in the print dialog box.
This is very annoying and I do not see why you would have changed the
behavior from the previous version.   Am I doing something wrong?  Is there
an option flag or something that I can set to make the rectangles non
opaque?
My particulars are:
Eagle Professional  5.4.0
OS:  Windows XP Pro SP3
Printer:  HP DeskJet 990cxi
Regards
Darren
  • Richard_H
    Richard_H over 16 years ago
    opaque?
    My particulars are:
    Regards
    Darren
    Please use a non-solid fill style and generate a PDF and print it.
    At the moment EAGLE does not support printing fill styles as it
    was in EAGLE 4.1. This is a problem of the current version of qt
    which is used for development. We will see what we can do for
    the future.
    Richard Hammerl
