EAGLE User Support (English) Changing name of copied part from existing library to "MyLibrary"
  • Subscribers 180 subscribers
  • Views 372 views
  • rename
  • part
  • library
britesc
britesc over 11 years ago
I have just started to create my own library of parts that I frequently use or want to use.
As I cannot find a diode 1N4001, I copied a 1N4004 from the dioide.lbr. I would like to remove all reference to it being a 1N4004 and replace it with 1N4001.
I have tried what for me are the logical ways, but to no avail.
I have read both the Dr Monk book and the Matthew Scarpino book, neither of them explain how to rename only how to copy.
Could some kind soul please tell me how to replace all reference to 1N4004 with 1N4001 in my library.
Thanks and kind regards,
jB
    On 08/11/14 12:30, britesc wrote:
    use or want to use.
    with 1N4001.
    Really? I'd have thought it was not that hard. Have you tried "HELP
    RENAME" for example?
    "All" references? There is only one! The device is called 1N4004 and it
    calls up a symbol called "D" and a package called "DO41-10", both of
    which are correct for a 1N4001.
    So if you go off and read the help, I think you should be able to figure
    it out for yourself. You will learn more by using your brain and the
    information already at your hands than by falling back on asking for
    hand-holding.
  • britesc
    0 britesc over 11 years ago in reply to autodeskguest
    Cadsoft Guest...
    Thank you for your arrogant reply. Clearly your comprehension of English is as limited as my experience of Cadsoft "replace all reference to 1N4004 with 1N4001 in my library." I said nothing about replacing the other values, may I suggest that you RTFQ whilst I RTFM.
    The answer though, did in fact help me, so thank you.
