EAGLE User Support (English) showing traces
  • Subscribers 178 subscribers
  • Views 1389 views
showing traces
e14candies
e14candies over 10 years ago
I am looking into some grounding routes & width issues.  How do you show
ONLY the ground traces, or whatever net name you want to see, all over the
board?  Basically I want to turn off the viewing of all nets other than the
one I specify.  I don't want to  muddy the image  with hundereds/thousands
of other traces.
    of other traces.
    you can't
    what you can do is highlight one or several nets with the show
    command.
    Lorenz
  • e14candies
    That's not good at all.  The highlighting really doesn't work, you still
    can't tell where the traces are.   You need to be able to show only the
    signal you are interested in seeing, to see how it is routed all around the
    board. There are too many traces crowding the screen to pick out the signal
    you want.
    This function should be added immediately, would be helpful
  • e14candies
    I suppose you can ripup everything that is not the trace you want to study,
    though this seems dangerous.  Then you can see clearly the pattern of the
    trace--where it zigzags around the board, branches, T's, alternates layers
    18 times, etc.
    If you undo, are there any issues with Eagle restoring everything back?  Of
    course with ripup, any editing done of the showing trace becomes a mess (in
    terms of thereafter restoring all the other traces).
    When can this issue be resolved??
    of other traces.
    What you can do is the following. The description assumes you are using
    the Black palette and default palette.
    Create/run  a script that changes the lowlight colours of the copper
    layers to a grey. At this point all your traces will be that colour.
    When you SHOW a net it will appear in the hi-light colour and it is very
    obvious where it routes to.
    When you are done with the grey view just run the script that comes with
    eagle defaultcolors.scr
    HTH
    Warren
    8551.grey_traces.scr.zip
  • e14candies
    THANKS--this approach does an excellent job.
    I think you can see why this viewing mode  is helpful
  • e14candies
    By the way, your attached picture is so wonderful--this should be the
    default show viewing mode, puts the current one to shame
