EAGLE User Support (English) Question marks show up in multi-sheet name labels
  • Views 1195 views
  • schematics
  • multisheet
  • schematic
I am trying to capture a multi-sheet schematic.  I am using same net names across sheets to make the connections.  When I apply net name labels that I see question marks being placed in the labels (e.g. RESET/2.??).  How do I get rid of these question marks?  Also what is the method to trace nets across sheets?  Thanks.
My platform:
Eagle Version 7.1.0
Macbook Air with OS X ver 10.9.5
    Thanks to eagle support I found out that the frame that I was generated with a ULP was not working.  Switched to a frame from frames library and it solved the issue.
