EAGLE User Support (English) Select one of overlapped objects
  • Views 640 views
  • overlapped
  • arbitrary
  • tips
  • select
How can I select arbitrary one of the overlapped objects?
Both of them are in the same layer!
    0 e14 Contributor over 11 years ago in reply to autodeskguest
    Thank you!
    Sometimes the "Next" menu does not appear, but I can select most of the arbitrary objects now.
    "Naoya Yamada"  skrev i nyhetsmeldingen:
    681686558.171416547335832.JavaMail.jive@flcspu-csapp-01.premierfarnell.com
    The context menu that appears when you right click, gets a "next" if there
    are several on the same spot.
    If you want to add items to a group, hold ctrl, left click and if one single
    item is highlighted, use right click to goto next, and left to select the
    hilighted. You will now notice its added to the group, as the full group
    gets hilighted again.
    Thanks Lorenz,
    but I have already tried it.
    However, when I right-clicked dense area, the menu was appeared and I couldn't select next object.
    I changed select-factor from 0 to 2, but I didn't get good result.
    have al look at "Selecting objects in dense areas" in the help
    Lorenz
