EAGLE User Support (English) Question about relays???
  • Subscribers 178 subscribers
  • Views 328 views
Im in the brainstorming stages of a circuit design and at a loss when it comes to the components i need. Im trying to use an arduino to power a large dc motor that needs 120v. Is there a type of relay that allows me to close a circuit separate from the arduino circuit. i would use two separate power sources, one for the arduino and one for the 120v each in their own circuit.
    Am 24.11.2014 um 07:24 schrieb Ethan Tanen:
    their own circuit.
    http://www.element14.com/community/message/132725
    Why don't you do your brainstorming in an Arduino forum?
    Here we discuss problems with eagle software and NOT with constructions.
    Joern Paschedag
  • D_Hersey
    0 D_Hersey over 11 years ago in reply to autodeskguest
    You want to drive your relay coil with a circuit that is opto-isolated, to make a long story short. . .  Triacs could be used instead of relays.
    https://www.fairchildsemi.com/application-notes/AN/AN-3003.pdf
    Do a search for "solid state relay"  - there are lots of them out there
    both for AC and DC that are optically isolated.
    mikey
