EAGLE User Support (English) Export gerber 274-X in mm
  • Subscribers 187 subscribers
  • Views 466 views
Hi all
I am trying to get the CAM processor to export gerber 274-x files using mm
instead of inches but i cannot seem to do it, does anyone know how?
Thank you
  • Richard_H
    Richard_H over 17 years ago
    Zaid schrieb:
    Hi all
    mm instead of inches but i cannot seem to do it, does anyone know how?
    Thank you
    Add in eagle.def:
    Type     = PhotoPlotter
    Long     = "Gerber photoplotter"
    Init     = "G01\nX000000Y000000D02\n"
    Reset    = "X000000Y000000D02\nM02\n"
    ResX     = 25400
    ResY     = 25400
    ;Wheel    = ""
    Move     = "X%0.6dY%0.6dD02*\n"    ; (x, y)
    Draw     = "X%0.6dY%0.6dD01*\n"    ; (x, y)
    Flash    = "X%0.6dY%0.6dD03*\n"    ; (x, y)
    Aperture = "%s*\n"               ; (Aperture code)
    Units    = mm
    Decimals = 4
    Info     = "Plotfile Info:\n"\
               "\n"\
               " Coordinate Format : 3.3\n"\
               " Coordinate Units  : mm\n"\
               " Data Mode         : Absolute\n"\
               " Zero Suppression  : None\n"\
               " End Of Block      : *\n"\
               "\n"
    @GERBER_MM_33
    Long          = "Gerber photoplotter with automatic aperture wheel
    generation"
    Wheel         = "" ; avoids message!
    AutoAperture  = "D%d" ; (Aperture number)
    FirstAperture = 10
    Decimals      = 4
    Units         = mm
    @GERBERAUTO_MM_33
    Long          = "Gerber photoplotter with RS-274-X aperture generation"
    Units         = mm
    Init          = "G75*\n"           \ allow positive and negative coordinates
                    "G71*\n"           \ units are mm
                    "%%OFA0B0*%%\n"    \ horizonal and vertical OFfset is 0
                    "%%FSLAX33Y33*%%\n"\ Format Statement is Absolute (I for
    incremental) 3.3
                    "%%IPPOS*%%\n"     \ Image Polarity is POSitive (NEG for
    nagative)
                    "%%LPD*%%\n"       \ Layer Polarity Dark (C for clear on
    negative planes)
                    "%%AMOC8\n5,1,8,0,0,1.08239X$1,22.5\n"\ Octagons are
    emulated with a circle (using 8 vertices)
                    "%%\n"            ; and therefore the diameter must be
    enlarged with '1 / cos(pi / 8)'
    Reset         = "M02*\n"
    Circle        = "%%AD%sC,%6.3f*%%\n"        ; (code, diameter)
    Rectangle     = "%%AD%sR,%6.3fX%6.3f*%%\n"  ; (code, dx, dy)
    Oval          = "%%AD%sO,%6.3fX%6.3f*%%\n"  ; (code, dx, dy)
    ; According to the RS-274-X specs there is an aperture macro
    ; primitive that allows us to specify an octagon (i.e. a polygon with
    ; 8 vertices). As some Gerber viewers seem to have problems with that,
    ; we would have to use a round shape for that.
    ; If your Gerber processor cannot handle the polygon primitive you may
    ; uncomment the following line and comment out the line after it:
    ;Octagon       = "%%AD%sC,%6.3f*%%\n"   ; (code, diameter) (looks like
    there is no octagon, so we take a circle)
    Octagon       = "%%AD%sOC8,%6.3f*%%\n" ; (code, diameter)
    Annulus       = "%%AMAN%s\n1,1,%6.3f,0,0\n1,0,%6.3f,0,0*\n"\
                    "%%\n"\
                    "%%AD%sAN%s*%%\n" ; (code, diameter, inner diameter,
    code, code)
    Thermal       = "%%AMTH%sX\n1,1,%6.3f,0,0\n1,0,%6.3f,0,0*\n"\
                    "21,0,%6.3f,%6.3f,0,0,45\n21,0,%6.3f,%6.3f,0,0,135\n"\
                    "%%\n"\
                    "%%AD%sTH%sX*%%\n"; (code, diameter, inner diameter,
    diameter + 2mil, gap, diameter + 2mil, gap, code, code)
    Richard Hammerl
