EAGLE User Support (English) Paste attribute not working in 7.2.0
  • Subscribers 179 subscribers
  • Views 449 views
In version 7.1.0, I could open the attributes of a part in the schematic capture, select an attribute and then paste (Ctrl-V) a value that was in the clipboard.  It was real handy for copying attributes for a part from a vendor website and populating the attributes of the part.  I just downloaded and installed 7.2.0 and this no longer works. I press Ctrl-V and nothing happens.  I also tried assigning Paste to Ctrl-V and still no luck.  What happened to this capability?  I had to go back to 7.1.0 so that I could continue working.  Thanks.
    Hi Bob,
    I hope you're doing well. Unfortunately, I can't reproduce this. I'm
    running V7.2.0 on a Windows XP machine and it works as expected. I also
    tried it on a Linux box (Xubuntu 12.04) and it seems to work just fine
    as well.
    hth,
    Jorge Garcia
    0 Former Member over 11 years ago in reply to autodeskguest
    Hello Jorge,
    I installed 7.2.0 on my Windows XP machine and it worked fine.  I'm currently running 7.2.0 on a Windows 7 Pro machine and having the problem.  Version 7.1.0 and 6.5.0 both work okay on my Windows 7 Pro machine.
    Bob
  • lesnoel
    0 lesnoel over 10 years ago in reply to Former Member
    I'm running Eagle 7.2.0 on an Window 7 PC and having the same problem....
    Aha!  I figured out the problem.  Webroot Secure Anywhere (anti-virus program) was blocking the clipboard paste feature for use in Eagle.  I don't know why it only caused a problem in version 7.2, but I changed the "Application Protection" to "Allow" for Eagle 7.2.  Now everything works as it should.
  • lesnoel
    Great!  Thanks for continuing the effort image
