How should I should report what I believe may be a library error?
Here is an extract from the Texas Datasheet for the TLV320AIC1110PBS and the schematic symbol in Eagle using the Texas Library shape. This TI Library was recently downloaded from the Element14 website. The library has name "Texas Instruments_By_element14_Batch_1". Description is "Developed by element14 :
element14 CAD Library consolidation.ulp at 30/07/2012 17:45:58".
TI Data Sheet: Eagle – Element14 – TI library (note pins 5 / 6 / 7).
My PCB ended up as per the Eagle symbol, which is wrong. I swapped the connections around for pins 5/6/7 with wire jumpers, to match the TI datasheet and then it worked.
How are the libraries maintained? Is their a query reporting and change process? Who maintains them?
Ian
