EAGLE User Support (English) I have a drill hole I can't select or delete, even after deleting everything else.
  • Views 2026 views
ryanneve
ryanneve over 11 years ago
I made a copy of my file and deleted every singe object and yet it remains. I opened up the .brd and .sch files in an editor and I think this may be the problem in both files:
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
Can I just delete the middle two lines using a text editor?
Thanks!
  • ryanneve
    0 ryanneve over 11 years ago in reply to autodeskguest
    I figured it out. What I though was a hole, was a DRC Drill distance warning symbol. Even when I deleted the part, the error symbol persisted. I didn't think to re-run the DRC or close and re-open.
    The error was caused by this:
    <package name="LCDDISPLAY5110">
    <pad name="DIN" x="3.302" y="23.495" drill="0.8" shape="long"/>
    <pad name="CLK" x="3.302" y="20.955" drill="0.8" shape="long"/>
    <pad name="DC" x="3.302" y="26.035" drill="0.8" shape="long"/>
    <pad name="VCC" x="3.302" y="18.415" drill="0.8" shape="long"/>
    <pad name="BL" x="3.302" y="15.875" drill="0.8" shape="long"/>
    <pad name="GND" x="3.302" y="13.335" drill="0.8" shape="long"/>
    <pad name="CE" x="3.302" y="28.575" drill="0.8" shape="long"/>
    <pad name="RST" x="3.302" y="31.115" drill="0.8" shape="long"/>
    <wire x1="0" y1="0" x2="45.339" y2="0" width="0.127" layer="21"/>
    <wire x1="45.339" y1="0" x2="45.339" y2="42.7228" width="0.127" layer="21"/>
    <wire x1="45.339" y1="42.7228" x2="0" y2="42.7228" width="0.127" layer="21"/>
    <wire x1="0" y1="42.7228" x2="0" y2="0" width="0.127" layer="21"/>
    <hole x="2.5019" y="4.1275" drill="3.175"/>
    <hole x="42.9133" y="4.1275" drill="3.175"/>
    <hole x="2.5019" y="38.6969" drill="3.175"/>
    <hole x="42.9133" y="38.6969" drill="3.175"/>
    </package>
    Note the two identical holes. I don't know how this happened. I checked the part and it looks fine. Deleting the part and inserting a new one fixes the problem.
    Thank you for your time.
    <classes>
    </class>
    </classes>
    that can't be the reason for your problem. This class definition is
    the default if you don't have any classes defined by yourself.
    It's present in any brd/sch I ever looked into.
    Can you post your files to the newsgroup (or the forum), so that other
    can have look at it?
    Lorenz
