EAGLE User Support (English) tengo problema en cam processor para generar los archivos
  • Subscribers 178 subscribers
  • Views 339 views
como puedo generar los global files en eagle
    http://www.element14.com/community/message/136391
    Hola Jose,
    Espero que estes bien. Te refieres a los archivos gerber? Si ese es el
    caso aqui te adjunto un procedimiento usando el CAM processor.
    2 Sided Board: Top and Bottom
    Gerber Generation:
    >From the Board Editor:
    1- Click on the CAM Process Icon
    2- In the CAM Processor click on File/Open/Job and select the CAM Job
    called Gerber_274X.Cam.
    3- Click on Process Job
    4- Click on File/Open/Job and select EXCELLON.CAM
    5- Click on Process Job.
    6- All the files will be located in your board directory with the same
    name of the board with different extensions:
    .CMP Component Side Copper   Top - Pad  - Via
    .SOL Solder Side Copper      Bottom - Pad  - Via
    .PLC Top Silk Screen         Dimension  - TPlace  - TName
    .STC Top Solder Mask         TStop
    .STS Bottom Solder Mask      BStop
    DRD Excellon Drill file.    Drills -  Holes
    MultiLayer Board:
    Gerber Generation:
    called Gerber_274X-4Layer.Cam.
    2a- Highlight the tab called Solder Side.
    2b- Click on the ADD button.  This will duplicate the currently selected
    tab.
    2c- Change the Name of the Section to Internal Layer n (n = whatever
    internal layer you have)
    2d- Change the file name output to .LYn (n = Layer number)
    2e- Select to correct layer combination:
         - If the internal layer is a signal layer then combine the                     internal
    layer with Pads and vias.
         - For versions prior to 6:If the internal layer is a Supply layer so
    the name on the
    layer
    list appears $GND or $VCC then make sure you only                select that layer only.
    2f- If you have more internal layers repeat steps 2a to 2e
    Saludos,
    Jorge Garcia
