EAGLE User Support (English) Removing Part Names from Board
  • Subscribers 189 subscribers
  • Views 1969 views
  • prototyping
  • layer
  • names
sailmike1
sailmike1 over 11 years ago
I am designing and building my own prototyping boards in Eagle. When I uploaded the board file to OSH Park the board image the site showed was not the board I thought I designed. The part names were included in the image on the website, but I don't want the names to show up. How do I get rid of the part names? I've attached a couple images to show what I mean. One image is how I want it to look and the other is what the OSH Park website showed.
Mikeimageimage
  • dukepro
    0 dukepro over 11 years ago in reply to sailmike1
    On 01/06/2015 03:06 AM, Michael Levin wrote:
    Yes that's correct. I'd also like to be able to remove specific items
    from the tplace layer like the number 1 next to the header.
    Make sure the top values layer is not included in the list of layers in
    your cam job section that generates the silk screen.
    A CAM job is essentially a recipe that describes each layer that the
    board house will fabricate.  Each layer to be fabricated is called a
    Section.  Each section contains the Eagle layers to include in that section.
    For example.  The section describing the top layer of copper, one would
    want to include, of course, Top.  Also desirable to include are the Pads
    layer and the Vias layer.  The union of all three of these layers will
    be fabricated as the top copper layer.  Another example is the top
    silkscreen layer.  Consider what you want to show up.  Component
    outlines are usually in the tPlace layer.  You definitely want reference
    designators (component names) so include the tNames layer as well.
    Another layer to include is the Dimension layer describing the board
    outline.  (This helps the board house align the layers.)  Others layers
    to consider including are the tDoc and the tValues.
    The device's package, as defined in an Eagle library, defines what text
    (or other objects) shows up on what layer.  Without jumping into the
    package editor, an easy way to figure out what you want to include on a
    layer is to use the DISPLAY command to turn off all layers except the
    ones of interest.  Try entering in the command line "display none tPlace
    tNames tValues".  To get back to the previous display, you can enter
    "display last" in the command line.
    Play with it some.  Find out what you want to include on the silkscreen
    layer, and adjust each section in your cam job accordingly.
    HTH,
        - Chuck
    1385.att1.html.zip
  • sailmike1
    0 sailmike1 over 11 years ago in reply to autodeskguest
    Yes that's correct. I'd also like to be able to remove specific items from the tplace layer like the number 1 next to the header.
    Mike
    http://www.element14.com/community/message/136591
    I am assuming you don't want the 3V1 and the MC78x... text.
    It looks like your cam job has the tvalues included.
