EAGLE User Support (English) What is the difference between GerberRS274x and GerberRS274X_25?
  • Subscribers 179 subscribers
  • Views 342 views
    http://www.element14.com/community/message/136771
    Hi Robert,
    The only difference here is in the resolution of the output. The _25
    variant gives you finer resolution by a factor of 10.
    You can normally just use the normal GerberRS274x driver, the _25
    variation was added due to requirements from certain boardhouses.
    hth,
    Jorge Garcia
    0 Former Member over 11 years ago in reply to autodeskguest
    Jorge,
    I just got finished comparing gerber files generated with both settings and your answer is what I was looking for.
    Robert Wolf
    0 autodeskguest over 11 years ago in reply to autodeskguest
    "Jorge Garcia"  skrev i nyhetsmeldingen: m8k47i$ggp$2@cheetah.cadsoft.de ...
    You can normally just use the normal GerberRS274x driver, the _25 variation
    I guess this is mostly a problem with fill areas. Since the Eagle/CAM is
    using wire fill, the rounding vs Eagle's built in constant overlap can make
    ultra-thin blank stripes in the fill pattern. Since manufacturers software
    try to convert fills into polygons, they fail if rounding is causing blank
    stripes.
    Imo, cadsoft should use an overlap vs rounding parameters that will ensure
    there is no blank stripes. Ideally the overlap should match whatever
    rounding the CAM does, but it is also important to keep wysiwyg in the
    editor.
    This is another reason for future Eagle versions to evolve from wire fill to
    proper polygon fill.
