EAGLE User Support (English) Beginner at eagle, dual layering help
  • Views 1430 views
I am currently working on my first project in Eagle, of which incorporates five passive components, a small weather station sensor, and an ATMEGA328p TQFP.
All of the items I am using are surface mount, making it difficult to route all on the top layer without any overlap. I therefore decided to use vias, send a top layer route to the via, then run another signal via the bottom layer from there to another via, then connect again a top layer route and send it to the associated pin. However whenever I attempt to connect a bottom layer route to the via, I get the error message "Can't set via to layer 16 at (x, y)".
What am I doing wrong here? Is my plan even possible to execute? I am very new to this, please go easy on me image
-Daniel
  • kgenskowsky
    0 kgenskowsky over 11 years ago
    I completely agree with the people before,
    The easiest way to learn and will just take a couple of hours is watch a couple of videos.
    https://www.youtube.com/results?search_query=eagle+tutorial
    0 autodeskguest over 11 years ago in reply to autodeskguest
    Rob Pearce wrote:
    On 12/01/15 18:06, Daniel Drexel wrote:
    I think what you're doing wrong is trying to do work yourself that Eagle
    will just handle. For example, you say you're "sending the top layer
    route to the via". This is wrong. It suggests you're placing vias then
    fiddling with their attributes then trying to route through them. That's
    just not how it's supposed to work.
    This is how you should work:
    Start your route at the pad. You will get a top layer trace. Route it to
    the open space where a via can be placed. Click there, then
    middle-click. Your trace is now on the bottom layer. Continue routing.
    When you click on the next route point, Eagle will automatically put
    the via where it's needed. Job done, no meddling.
    And in the board editor, be sure you've actually defined a two-layer board
    with vias in the DRC layers dialog, eg, (1*16).
    Note that the single most common mistake made by those new to Eagle (or
    anything else, for that matter) is to not work through the tutorial, slowly,
    first.
    Bob
    When routing with via's you can use two methods:
    1. Place a short section or wire on the top layer and then switch the layer to the bottom and a via will automatically be placed.  Note the key is you must route a short section on the top first.
    2. Manually place a via and make sure you rename it to the net that you are trying to route and ratsnest will connect it for you.
