EAGLE User Support (English) how to measure distance accurately in PCB?
  • Subscribers 178 subscribers
  • Views 1138 views
  • distance
  • measure
  • accurately
How to measure distance accurately in PCB?
All my electronic components have positional constraints and I need a accurate way to place them on PCB.
(I an on EagleV7.2 Standard Edition)
Durand Jean-Romain
Electronics engineer, WIMOVE
    autodeskguest over 11 years ago +1
    On 16/01/15 07:54, Jean-Romain Durand wrote: How to measure distance accurately in PCB? All my electronic components have positional constraints and I need a accurate way to place them on PCB. (I an on…
    If your actual requirement is to accurately place components, the
    easiest way is to use to command line, for example:
       move SW1 (1.005 2.100);
    This allows placement with full precision independently of the current grid.
    0 autodeskguest over 11 years ago in reply to autodeskguest
    or use the info dialog to manipulate the position after placement
    Lorenz
    0 Former Member over 11 years ago in reply to autodeskguest
    Firstly thank you for your answer,
    If I use the command line like you exemple, the components in my library should have the right "0-coordinate" in the center of it. Isn't it?
    Because I am not sure of the center definition of all my components
    0 autodeskguest over 11 years ago in reply to Former Member
    then you will to have to verify the package in the library editor.
    In the board editor right-click on a part and select "open package".
    Now you can verify the coordinates of the pads using the info command.
    Lorenz
