EAGLE User Support (English) clearance for therm pads
  • Views 565 views
Janvi
Janvi over 11 years ago
we have a GND polygon for plane area with pads inside.
Unfortunately our thermal pads have insufficient clearance.
Properties for the poly line shows a setup dialog with
Width - to adust the width of connectors between plane and pads.
The width works well within limits and we set this to 0,2mm.
Plane always generates 4 connectors with 0/90/180/270 degree
if there is enough space for. Where is it possible to set a default
of 2 connectors (e.g. 0/180 degree)?
Spacing - is useless for the clearance of therm pads and obviously
only works for hatch patterns and not for thermal pads
Isolate - is useless becouse it only adjust the isolation space to
other nets and not the gap of the therm pad.
For the moment, the thermal isolation gap is only 0,25mm and we cannot
find the parameter to adjust this. On the other hand, we have very old boards
what show approx 0,5mm space for thermpads in physical copper. Retrieving
this desings and output new Gerber without changes cannot produce the
former resulsts.
  • Jorge_Garcia
    0 Jorge_Garcia over 11 years ago
    Hi Janvi,
    I hope you're doing well. Thermal connections are always attempted using 4 spokes there's no way to change that. By thermal isolation I understand the separation between the polygon and the pad itself. Go into the DRC > Thermals tab, that parameter defines the isolation between polygons and the pad they connect to with thermal. By default it's set to 10 mils.
    Best Regards,
    Jorge Garcia
    The Thermal isolation parameter is on the "Supply" tab of the DRC
    settings dialog.
