EAGLE User Support (English) Eagle library for Bounrs is missing parts that element14 sells
  • Subscribers 180 subscribers
  • Views 404 views
Maybe there's a different library, but I'm looking for an SRP1038A--330M  INDUCTOR, SHIELDED, 33UH, 20%, 3.5A, and the one offered doesn't include it....
    I'm having this issue with multiple parts
    0 michaelkellett over 11 years ago in reply to Former Member
    Just make your own parts - I almost never use stock library symbols or footprints.
    Why - because footprints should be optimised for your assembly process - I mainly solder prototypes by hand so I use pads that extend beyond the chips when possible so I can get an iron to them - this would be daft if I were reflow soldering.
    Dastard symbols (for schematics) are fine for simple things like resistors and capacitors but for more complicated stuff you will often get a MUCH clearer schematic if you customise the symbol for the design.
    Add to that the need to carefully check anything you use from a standard library ......
    It's well worth the time and trouble learning how to roll your own.
