EAGLE User Support (English) Eagle 5.5 Autoroute
  • Replies 13 replies
  • Subscribers 181 subscribers
  • Views 898 views
Eagle 5.5 Autoroute
Former Member over 16 years ago
I have an existing board design that auto-routes fine with v5.4, but only
routes to 96% with v5.5
Same board... no changes.
This has forced me to revert back to v5.4
The board is fairly large (7.5x3.5 inches) with 1 100pin QLFP chip and a few
other 14/16pin SMT chips.
I have been using Eagle for several years with much more complex designs
(BGA,etc.) but I can't seem to get this fairly simple board to auto-route
with 5.5
Are there any settings in 5.5 that are more 'sensitive' than in 5.4?
Peter
    Klaus
    What file(s) will you need?... *.BRD as well as the EAGLE.EPF?
    Can I e-mail these directly to you instead of using the Newsgroup?
    Peter
    "Klaus Schmidinger" <Klaus.Schmidinger@cadsoft.de> wrote in message
    news:gtcc2h$bm9$1@cheetah.cadsoft.de...
    On 04/30/09 16:15, pch wrote:
    Klaus
    I have downloaded and tested v5.5.1
    I have tried 2 boards that autoroute 100% in v5.4
    Both boards did not autoroute ok.
    One autorouted to 97.3%, the other slighly better.
    Any ideas?
    Can you send me one of these boards for testing?
    Klaus Schmidinger
    Hofmark 2                               Email:   kls@cadsoft.de
  • kcadsoft
    kcadsoft over 16 years ago
    On 30.04.2009 16:36, pch wrote:
    Klaus
    Just the *.brd file.
    Absolutely. And rest assured your data will be treated confidentially.
    Klaus Schmidinger
    Klaus
    Any ideas?
    Klaus Schmidinger
  • kcadsoft
    Klaus
    The problem is that as of version 5.5 the autorouter no longer produces
    long diagonal snap wires from the borders of pads/smds to their centers,
    because that has sometimes caused DRC errors.
    In your case this means that some pads of IC1 could no longer be reached.
    After a closer look I found that the routing grid could have been chosen
    much better. So I set the routing grid to 0.25mm (note: millimeter, not mil!)
    to better match the 0.5mm pitch of IC1. I also moved IC1 into a 0.5mm
    grid, so that its pads are centered on the routing grid.
    After that the board was auto-routed 100% in under one minute.
    Klaus Schmidinger
