EAGLE User Support (English) Eagle 5.5 Autoroute
  • Replies 13 replies
  • Subscribers 180 subscribers
  • Views 873 views
Eagle 5.5 Autoroute
Former Member over 16 years ago
I have an existing board design that auto-routes fine with v5.4, but only
routes to 96% with v5.5
Same board... no changes.
This has forced me to revert back to v5.4
The board is fairly large (7.5x3.5 inches) with 1 100pin QLFP chip and a few
other 14/16pin SMT chips.
I have been using Eagle for several years with much more complex designs
(BGA,etc.) but I can't seem to get this fairly simple board to auto-route
with 5.5
Are there any settings in 5.5 that are more 'sensitive' than in 5.4?
Peter
    Compare the DRC and Autorouter rules between the different instances of
    5.4 and 5.5 . You are able to save the settings for both of these and
    import them into v5.5 . Make sure you save the original v5.5 rules !
    If v5.5 routes 100%, you may want to see what values differ between the
    v5.4 and v5.5 rules.- ted
    ted@markson.us
    with 5.5
    Peter
  • kcadsoft
    kcadsoft over 16 years ago
    with 5.5
    Looks like a bug has crept into version 5.5 that causes this.
    We're currently debugging it...
    Klaus Schmidinger
    Hofmark 2                               Email:   kls@cadsoft.de
  • kcadsoft
    with 5.5
    Fixed for version 5.5.1.
    Klaus Schmidinger
    "Klaus Schmidinger" <Klaus.Schmidinger@cadsoft.de> wrote in message
    news:gsp7ut$vmv$1@cheetah.cadsoft.de...
    few
    with 5.5
    Klaus Schmidinger
    Hi Klaus,
    Would this issue have anything to do with getting this error:
    "Invalid data in autorouter block of file:  Continue with default autorouter
    settings?"
    I am using EAGLE 5.4, generating CAM output from a customer's file (unknown
    format).
    Or is this due to the new 'Follow Me' mode for the ROUTE command?
    Terri
  • esilviu
    esilviu over 16 years ago
    "Terri Miller" <tmiller@sunstone.com> wrote in message
    news:gstaj2$c0h$1@cheetah.cadsoft.de...
    autorouter settings?"
    (unknown format).
    Nop, it's because your customer used Eagle 5.5 to save the file, and you are
    using 5.4.
    At least that the reason I get this message
  • kcadsoft
    few
    with 5.5
    Klaus Schmidinger
    Hi Klaus,
    settings?"
    format).
    Files edited with version 5.5 have a new section "Follow-me" in the
    Autorouter setup, which version 5.4 can't handle. That's why this
    message is given. If you only generate CAM data, you can safely
    ignore this message.
    Klaus Schmidinger
    Where can I find version 5.5.1?
    with 5.5
    Klaus Schmidinger
  • kcadsoft
    This will be our next beta version, which will become available shortly.
    It will be announced in eagle.betatest.
    Klaus Schmidinger
    Former Member over 16 years ago in reply to kcadsoft
    Klaus
    I have downloaded and tested v5.5.1
    I have tried 2 boards that autoroute 100% in v5.4
    Both boards did not autoroute ok.
    One autorouted to 97.3%, the other slighly better.
    Any ideas?
    Peter
    news:gspkoh$tk4$1@cheetah.cadsoft.de...
    only
    few
    auto-route
    with 5.5
    Klaus Schmidinger
  • kcadsoft
    On 04/30/09 16:15, pch wrote:
    Klaus
    Any ideas?
    Can you send me one of these boards for testing?
    Klaus Schmidinger
