EAGLE User Support (English) Mac "corrupting" LBR files?
  • Replies 11 replies
  • Views 2326 views
A friend and I share projects, both using Eagle 7.2.0.  He recently started using a Mac, and now it seems if he saves a Library file, it gets "changed" by the Max such that I can't use it in Windows any more.  The error I get is:
Loading C:/Users/GA93335/Desktop/PCB/PIC24LIB.lbr ...
Error:
line 1, column 1: Start tag expected.
If I open the LBR file in Notepad I get a bunch of "oddball" stuff, but I don't know what should be there.  Is it possible the Mac is using a path or some other nomenclature in the file that "messes it up" for use in Windows?
I have attached one LBR file here (changed the extension so it would attach).  I am unable to use it in Windows (tried on 2 different computers), but it works fine on the Mac.  What do I have to do to "fix" it so both of us can use it?
PIC24LIB.txt.zip
    So I looked at other LBR files (from Windows) and they are "easy to read" xml files.  As I said once saved on the Mac it gets converted to a bunch of "crap"...
    I guess I might try to open the LBR file in a text editor on the Mac and see if we can copy/paste that way...  Maybe encryption or compression is used on the Mac?  Any other thoughts?
    0 Former Member over 11 years ago in reply to Former Member
    Looks like "copy/paste" from the Mac caused the issue.  Opening the file in the Mac and saving the contents as a TXT file, and renaming to LBR restores functionality, so somehow there is either encryption or compression in the drag-and-drop that "breaks" it...
    Problem solved!
  • gpsmikey
    0 gpsmikey over 11 years ago in reply to Former Member
    I would be suspicious of a "newline" vs CR/LF issue - Mac's are basically
    Linux based and Linux uses one type of line terminator while windowz uses
    the other (I have had to use sed in the Linux world before to convert text
    files generated on the Linux machine to a format that windows apps could
    read).
    mikey
    0 autodeskguest over 11 years ago in reply to gpsmikey
    Not likely to cause what the OP was reporting.
    Mac's are basically
    the other
    Also not quite true. MacOS-X may be BSD-derived but it retains the
    original Mac newline which is different from both Windows and Linux.
    I don't know what MacOS does with unicode but that sounds more likely to
    be the cause of the "bunch of crap" reported. However, I'd also be
    suspicious of the Mac being "too smart for its own good" and encrypting
    files with a .LBR extension (or prefixing them with a "this is the X86
    version" tag), especially if converting to a text file fixed it!
    0 autodeskguest over 11 years ago in reply to Former Member
    Am 03.02.2015 um 21:47 schrieb mike phillips:
    in the Max and saving the contents as a TXT file, and renaming to LBR
    Problem solved!
    http://www.element14.com/community/message/139309
    A library file created with EAGLE under Mac does not differ at all
    from a library file created under Windows or Linux. Could you please
    send the "cryptic" file so we can check?
       ==> support@cadsoft.de
    Richard Hammerl
  • gpsmikey
    0 gpsmikey over 11 years ago in reply to autodeskguest
    Rob Pearce wrote on Tue, 03 February 2015 23:34
    Mac's are basically
    windowz uses
    the other
    to
    encrypting
    Good points - I was not aware Mac's used yet another line termination
    character.  I do know in windows, Linux/Unix created files can be opened
    in wordpad and they look right and in notepad, it can't handle the
    line termination so it all runs together.  Definitely time for a file
    compare utility to see just what the differences are.
    mikey
    This is NOT a line termination issue!  The Mac file is attached to the first post, and the contents if 99% "unintelligible".  And I have resolved the issue.  Consider this case closed (and use Eagle to transfer libraries between Mac/PC, not file copy on the Mac!).  A SHORT snippet of the file is:
    book    mark    8   8   °           €`  Ɔ>F7ºA    ÿ  Äÿ                      Applications        EAGLE-7.1.0         lbr         PIC24LIB.lbr            $   8   D           ÷´              ‚¾.             ξ.             1¼=             p   €                  Aº2Ê                                                  file:///        Macintosh HD           è           A¹^±Æ   $       BBDAE6CD-3238-373A-9D78-21AFFC5AD851               ï       ï               /   3       dnib                                lbr????         aü      icns  üaTOC    Xis32   Ós8mk    ic11   ²il32   4l8mk    it32  2ñt8mk  @ ic10  Ô ic10  Ô ic10  Ô is32   ӏ  @}€  €€@ƒ
    @~€€À  €€@¿‚  @~ Àß €€ @ÿ€~€  @~€€ÀÀ €€@ÿ€€€  @~€€  À€€@ÿ€€€  @~„€ @ÿ€€€  @~„€ @ÿ€€€  @~€½ `€@ÿ€€€  @~€  @€@ÿ€€€  @~€>€  @€@ÿ€€€  @}€  €€@ÿ€€Š  ÿ€€‹  S€‚  )†@ €ƒ ‡~    @}€  €€@ƒ
    @~€€À  €€@¿‚  @~ Àß €€ @ÿ€~€  @~€€ÀÀ €€@ÿ€€€  @~€€  À€€@ÿ€€€  @~„€ @ÿ€€€  @~„€ @ÿ€€€  @~€½ `€@ÿ€€€  @~€  @€@ÿ€€€  @~€>€  @€@ÿ€€€  @}€  €€@ÿ€€Š  ÿ€€‹  S€‚  )†@ €ƒ ‡~  Copyright  ¿Œ  ÿ€~Š  ÿ€€Š  ÿ€€Š  ÿ€€Š  ÿ€€ƒ ~€  ÿ€€Š  ÿ€€Š  ÿ€€ƒ @€  ÿ€€Š  ÿ€€‹  S€‚  )†@ €ƒ ‡~  s8mk      €€€€€€€€€€      ÿ¿ÿÿÿÿÿÿÿÿ@     ÿ€ÿÿÿÿÿÿÿÿÿ€    ÿ€ÿÿÿÿÿÿÿÿÿÿ€   ÿ€ÿÿÿÿÿÿÿÿÿÿÿ   ÿ€ÿÿÿÿÿÿÿÿÿÿÿ   ÿ€ÿÿÿÿÿÿÿÿÿÿÿ   ÿ€ÿÿÿÿÿÿÿÿÿÿÿ   ÿ€ÿ€€€€ÿÿÿÿÿÿ   ÿ€ÿ@   ÿÿÿÿÿÿ   ÿ€ÿ€€€€ÿÿÿÿÿÿ   ÿ¿ÿÿÿÿÿÿÿÿÿÿÿ   ¿€€€€€€€€€¿ÿÿ   @@         ¿ÿ    @¿ÿÿÿÿÿÿÿÿÿÿ      €€€€€€€€€€ ic11   ²‰PNG
    IHDR             szzô    sRGB RegisteredÎ é  pHYs   %   % IR$ð   OIDATXí–  ƒ  EÝâ½Á“;Š–Tèï*8—,3YZJé ‡NÓ—¯‡¢¿*±‘¦QêÍÅ NŒb0àzê<Qý´Ø$—ëB£Æ7;
    š2"  É_ 1Y¹ëšõ!D  k¼ ç< Ñ€t xÅ+   «>„evwdËyÎj;çh6Ƙ»l~Æ\ µ  í€ C±î- ( AÅ=ñn OqON  oYî„GLËé ¨ 1P ÷Œ/ ð ¡œ?ÀCopyright „°¤È¢6[q7 ½ é2¬¥ çÜ °ÂàÄY€æm6¨ú(Î/QQ¹Þ݁´÷t÷ÖOÖuûn ªH  Z·ªH„ û ‹T:÷· @öì ÌZ Ýå]—
    Ä/{ØÒÑA[ ÿ=Ú 8\ÐÓ :ÀÐ:
    €roƒ@[ð     C¤¿Þö%«  ¡-8ÔåOèCðW /{$dF3°½6    IENDRegisteredB`‚il32   4 €‹  € ‡€ ÿ‚€‹  € ƒ€ ÿ€€ÿƒ€  ÿ‰  € ƒ€ ÿ€ÿ„€  ÿÿˆ  € ƒ€ ÿÿ…€  €ÿ‡  € €€‚ÿ†€  €ÿ  €€„  € ƒ€ ÿÿ…€  €ÿ  €€„  € ƒ€ ÿ€ÿÿƒ€  €ÿ  €€„  € ƒ€ ÿ€ÿÿƒ€  €ÿ  €€„  € ‡€ ÿ‚€  €ÿ  €€„  € €  €ÿ  €€„  € €  €ÿ  €€„  € €  €ÿ  €€„  € €  €ÿ  €€„  € € ÿ€ÿ€ÿ€ÿ‚€  €ÿ  €€„  € €€† €  €ÿ  €€„  € €€† €  €ÿ  €€„  € €€† €  €ÿ  €€„  € €€† €  €ÿ  €€„  € €… €  €ÿ  €€„  € € ÿ€ÿ€ÿ€ÿ‚€  €ÿ  €€„ €  €ÿ  €€— €ÿ  €€˜  ÿÿ €€Tm  ÿ €€›  €€›  €€ˆ ’€‰ ‘€Ÿ  €‹  € ‡€ ÿ‚€‹  € ƒ€ ÿ€€ÿƒ€  ÿ‰  € ƒ€ ÿ€ÿ„€  ÿÿˆ  € ƒ€ ÿÿ…€  €ÿ‡  € €€‚ÿ†€  €ÿ  €€„  € ƒ€ ÿÿ…€  €ÿ  €€„  € ƒ€ ÿ€ÿÿƒ€  €ÿ  €€„  € ƒ€ ÿ€ÿÿƒ€  €ÿ  €€„  € ‡€ ÿ‚€  €ÿ  €€„  € €  €ÿ  €€„  € €  €ÿ  €€„  € €  €ÿ  €€„  € €  €ÿ  €€„  € € ÿ€ÿ€ÿ€ÿ‚€  €ÿ  €€„  € €€† €  €ÿ  €€„  € €€† €  €ÿ  €€„  € €€† €  €ÿ  €€„  € €€† €  €ÿ  €€„  € €… €  €ÿ  €€„  € € ÿ€ÿ€ÿ€ÿ‚€  €ÿ  €€„ €  €ÿ  €€— €ÿ  €€˜  ÿÿ €€Tm  ÿ €€›  €€›  €€ˆ ’€‰ ‘€Ÿ ÿ “  ÿœ  ÿÿ› €ÿš €ÿ  €€— €ÿ  €€— €ÿ  €€— €ÿ  €€— €ÿ  €€— €ÿ  €€— €ÿ  €€— €ÿ  €€— €ÿ  €€Š  ÿ ÿ ÿ ÿƒ €ÿ  €€— €ÿ  €€— €ÿ  €€— €ÿ  €€— €ÿ  €€— €ÿ  €€Š  ÿ ÿ ÿ ÿƒ €ÿ  €€— €ÿ  €€— €ÿ  €€˜  ÿÿ €€Tm  ÿ €€›  €€›  €€ˆ ’€‰ ‘€Ÿ l8mk                                        ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ            ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ            ÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ           ÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ          ÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ        ÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ        ÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ      ÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ      ÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ      ÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ      ÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ      ÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ      ÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ      ÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ      ÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ      ÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ      ÿÿ ÿÿÿ        ÿÿÿÿÿÿÿÿÿÿÿÿ      ÿÿ ÿÿÿ        ÿÿÿÿÿÿÿÿÿÿÿÿ      ÿÿ ÿÿÿ ÿ      ÿÿÿÿÿÿÿÿÿÿÿÿ      ÿÿ ÿÿÿ        ÿÿÿÿÿÿÿÿÿÿÿÿ      ÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ      ÿÿ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ      ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ      ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ      ÿ                    ÿÿÿÿÿ       ÿ                    ÿÿÿÿ        ÿ                    ÿÿÿ         ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ           ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ            ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ                                  it32  2ñ    ÿ ÿ ÿ ÿ ÿ ÿ ÿ ‚          ²    0Â@ 0  ²   0HÂ` H0 ²   @`€ `@ ²   @`€€~ }€~¢€ ˆ˜ ˜ˆŽ€ `@ ²
    @`€~}}~}}~¢€  °À° Ž€ `@ ²
    @`€~}}|}}~¢€ ˜°Çßǰ˜Ž€ `@ ²
    @`€}~| |~}¢€  ÀßÿßÀ Ž€ `@ ²
    @`€}~| |~}’€ ˆ˜ ˜ˆ‚€
    ˆ˜ °ÀÏßǰ˜Ž€
    `@    0@90 ª
    @`€}~| |~}’€  °À° ‚€  °‚À ° Ž€
    `@   @`€kS0ª
    @`€}~| |~}’€ ˜°Çßǰ˜‚€
    ˜°ÇßÏÀ° ˜ˆŽ€
    `@  0`¿˜k9ª
    @`€}~| |~}’€  ÀßÿßÀ ‚€  ÀßÿßÀ ’€
    `@  @€¿ÿ¿€@ª
    @`€}~| |~}’€  ÀßÿßÀ €ˆ˜ °ÀÏßǰ˜’€ `@  @€¿ÿÏŸp@90 ¦
    ÀßÿßÀ € °‚À ° ’€ `@  @€¿ÿß¿Ÿ€kS0¦
    @`€}~| |~}’€  ÀßÿßÀ €˜°ÇßÏÀ° ˜ˆ’€ `@  @€¿ÿïßÏ¿˜k9¦
    @`€}~| |~}’€  ÀßÿßÀ € ÀßÿßÀ –€ `@  @€¿‚ÿ ¿€@¦
    @`€}~| |~}’€  Àßÿçϸ °ÀÏßǰ˜–€ `@  @€¿‚ÿ ÏŸp@0  ¢
    @`€}~| |~}’€  ÀßÿïßÏ‚À ° –€ `@  @€¿‚ÿ ß¿Ÿ€`@ ¢
    @`€}~| |~}’€  Àßÿ÷ïçßÏÀ° ˜ˆ–€ `@  @€¿‚ÿ ïßÏ¿`0¢
    @`€}~| |~}’€  Àß‚ÿ ßÀ š€ `@  @€¿†ÿ ¿€@¢
    @`€}~| |~}‚€ ˆ˜Š
    ¸Ïçÿ÷ïçßǰ˜š€ `@  @€¿†ÿ ¿€@ 4‚| zxp–
    @`€}~| |~}‚€  °ŠÀ
    ÏßïÿïßÏÀ° š€ `@  @€¿†ÿ ¿€@  )K‚~ }|x–
    @`€}~| |~}‚€ ˜°ÇŠß
    çï÷ÿçϸ ˜ˆš€ `@  @€¿†ÿ ¿€@  6W„} z–
    @`€}~| |~}‚€  Àߎÿ ßÀ ž€ `@  @€¿†ÿ ¿€@  @`‚€ }~|–
    @`€}~| |~}‚€ ˜°ÇŠß
    çï÷ÿçϸ ˜ˆš€ `@  @€¿†ÿ ¿€@  @`‚€ }~|–
    @`€}~| |~}‚€  °ŠÀ
    ÏßïÿïßÏÀ° š€ `@  @€¿†ÿ ¿€@  @`‚€ }~|–
    @`€}~| |~}‚€ ˆ˜Š
    ¸Ïçÿ÷ïçßǰ˜š€ `@  @€¿†ÿ ¿€@  @`‚€ }~|–
    @`€}~| |~}’€  Àß‚ÿ ßÀ š€ `@  @€¿†ÿ ¿€@  @`‚€ }~|–
    Àßÿ÷ïçßÏÀ°‚  ˜ˆ’€ `@  @€¿†ÿ ¿€@  @`‚€ }~|–
    @`€}~| |~}’€  ÀßÿïßφÀ ° ’€ `@  @€¿†ÿ ¿€@  @`‚€ }~|–
    Àßÿçϸ °ÀÏ‚ß Ç°˜’€ `@  @€¿†ÿ ¿€@  @`‚€ }~|–
    ÀßÿßÀ € Àß‚ÿ ßÀ ’€ `@  @€¿†ÿ ¿€@  @`‚€ }~|–
    ˜°Çßǰ˜€˜°Ç‚ß ÏÀ° ˜ˆŽ€ `@  @€¿†ÿ ¿€@  @`‚€ }~|–
  • dukepro
    0 dukepro over 11 years ago in reply to Former Member
    Mike,
    After unzipping the attachment in the original post, Linux was able to
    identify this file as a "MacOS Alias file".  In contrast, Linux will
    identify a real library as "XML document text".  Being unfamiliar with
    OSX, I'm not sure what a MacOS Alias file is, but maybe it will provide
    a clue as to how to get the Mac to behave.
    A hexdump reveals the first 256 bytes as:
        0000: 62 6f 6f 6b 00 00 00 00  6d 61 72 6b 00 00 00 00  book....mark....
        0010: 38 00 00 00 38 00 00 00  b0 00 06 00 00 00 04 10  8...8...........
        0020: 00 00 00 00 80 60 00 00  c6 86 3e 46 37 81 ba 41  .....`....>F7..A
        0030: 00 00 00 00 ff 7f 00 00  c4 ff 05 00 04 00 00 00  ................
        0040: 03 03 00 00 00 04 00 00  0c 00 00 00 01 01 00 00  ................
        0050: 41 70 70 6c 69 63 61 74  69 6f 6e 73 0b 00 00 00  Applications....
        0060: 01 01 00 00 45 41 47 4c  45 2d 37 2e 31 2e 30 00  ....EAGLE-7.1.0.
        0070: 03 00 00 00 01 01 00 00  6c 62 72 00 0c 00 00 00  ........lbr.....
        0080: 01 01 00 00 50 49 43 32  34 4c 49 42 2e 6c 62 72  ....PIC24LIB.lbr
        0090: 10 00 00 00 01 06 00 00  10 00 00 00 24 00 00 00  ............$...
        00a0: 38 00 00 00 44 00 00 00  08 00 00 00 04 03 00 00  8...D...........
        00b0: f7 b4 18 00 00 00 00 00  08 00 00 00 04 03 00 00  ................
        00c0: 82 be 2e 00 00 00 00 00  08 00 00 00 04 03 00 00  ................
        00d0: ce be 2e 00 00 00 00 00  08 00 00 00 04 03 00 00  ................
        00e0: 31 bc 3d 00 00 00 00 00  10 00 00 00 01 06 00 00  1.=.............
        00f0: 70 00 00 00 80 00 00 00  90 00 00 00 a0 00 00 00  p...............
    and the last few bytes as:
        60000: fe ff ff ff 01 00 00 00  00 00 00 00 12 00 00 00
        60010: 04 10 00 00 58 00 00 00  00 00 00 00 05 10 00 00
        ....X...........
        60020: b0 00 00 00 00 00 00 00  10 10 00 00 d8 00 00 00
        60030: 00 00 00 00 40 10 00 00  c8 00 00 00 00 00 00 00
        60040: 02 20 00 00 90 01 00 00  00 00 00 00 05 20 00 00  .
        60050: 00 01 00 00 00 00 00 00  10 20 00 00 10 01 00 00  .........
        60060: 00 00 00 00 11 20 00 00  44 01 00 00 00 00 00 00  .....
        ..D.......
        60070: 12 20 00 00 24 01 00 00  00 00 00 00 13 20 00 00  .
        60080: 34 01 00 00 00 00 00 00  20 20 00 00 70 01 00 00  4.......
        ..p...
        60090: 00 00 00 00 30 20 00 00  f8 00 00 00 00 00 00 00  ....0
        600a0: 01 d0 00 00 f8 00 00 00  00 00 00 00 10 d0 00 00
        600b0: 04 00 00 00 00 00 00 00  17 f0 00 00 44 00 00 00
        ............D...
        600c0: 00 00 00 00 20 f0 00 00  d8 01 00 00 00 00 00 00  ....
        600d0: 22 f0 00 00 9c 01 00 00  00 00 00 00 00 fe 00 00
        600e0: 44 fe 05 00 00 00 00 00                           D.......
    Pretty nondescript, wouldn't you say?
    With that said, I noticed that the ZIP file was only a fraction smaller
    than the TXT file.  This would indicate that the TXT file may already be
    compressed.  As you are aware, plain text files such as XML are often
    compressed by zip to 15% or less of the original size.
    I have a library that's about 2.5M.  I compressed it with zip and got
    the following:
        chuck@tomcat:~> unzip -lv t.zip
        Archive:  t.zip
         Length   Method    Size  Cmpr    Date    Time   CRC-32   Name
         2694540  Defl:N   271190  90% 2015-01-30 16:15 62db4a6b
        eagle/lbr/chuck.lbr
         2694540           271190  90%                            1 file
    90% compression... Not bad.
    By comparison:
        chuck@tomcat:~> unzip -lv /tmp/PIC24LIB.txt.zip
        Archive:  /tmp/PIC24LIB.txt.zip
          393448  Defl:N   321129  18% 2015-02-03 18:14 94d3e76a  PIC24LIB.txt
          393448           321129  18%                            1 file
    A good hypothesis might be that the Mac system is keeping the file
    compressed, or stored on a compressed drive.  Could the file that gets
    attached to an email remain in compressed form?
    I don't have any solid answers for you, but perhaps I have provided a
    direction to investigate.
    HTH,
        - Chuck
    0 autodeskguest over 11 years ago in reply to dukepro
    from wikipedia:
    In Mac OS System 7 and later, an alias is a small file that represents
    another object in a local, remote, or removable[1] file system and
    provides a dynamic link to it; the target object may be moved or
    renamed, and the alias will still link to it (unless the original file
    is recreated; such an alias is ambiguous and how it is resolved
    depends on the version of OS X). In Windows, the same function is
    performed with a "shortcut", a file with a .lnk extension.
    So it looks a if the OP didn't get the library file at all, but a some
    sort of symbolic link (MacOS style).
    Lorenz
    0 autodeskguest over 11 years ago in reply to autodeskguest
    Which would also explain why his fix worked: the MacOS text editor he
    loaded it into would be "alias aware" and load the referenced file
    instead. On a "Save as...", it wouldn't need to make a new alias, just
    write a plain file.
