EAGLE User Support (English) Two trace widths on the same net
  • Subscribers 178 subscribers
  • Views 1009 views
firatkocak
firatkocak over 16 years ago
I am designing a simple development board for myself. The mcu is
Pic18F8722 and because of its pin pitch limitation, i have to use 8 mil
for trace width. For i/o signals it is ok but i want power lines to be
at least 10 mil. Is it possible to tell the auto router to shift 8 mil
before entering mcu pins ? If it is not possible with auto router , what
would you advise to accomplish this ?
Best regards,
Firat Kocak
    i don't think the difference between 8 and 10mil is worth worrying
    about, but i would make power connections as fat as possible :-). and
    yes, at least in v4 of EAGLE it is easy to make the trace widths change
    anywhere you want. you just use the CHANGE:WIDTH function and you can
    manually make any segment of any net whatever width you want.
    to do it automatically, make a "class" for the nets you want to be
    different sizes and assign a width to that class and then change the
    class for all the nets for which you want the wide width.
    most people route power connections by hand first along with any
    critical nets that need to be in specific places and then let the
    autorouter clean up the rest. if you do this, you may find that it's not
    even worth making a class for the power nets, you just set their size as
    you route them.
  • firatkocak
    Thanks for the reply.
    Gary Gofstein yazmış:
    about,
    Me too. But i feel more confident when power lines are as much as tick.
    but i would make power connections as fat as possible image.
    I agree.
    and
    I know this but it is done in pcb, after routing is finished. And
    changing a routed trace width something thicker then the older mostly
    causes DRC error.
    The problem itself begins here. I set all lines connected to mcu pins to
    default class ( 8 mil ) and made a new class for the other lines (
    power_line_1 , which is 10 mil ). But mcu has 5 vcc and 5 gnd pins which
    i want to be 10 mil. Other ICs accept 10 mil power lines but not Mcu.
    you route them.
    Yes. It would be a good solution, if my design became 4-layered. After
    routing has finished the job, it is difficult to find empty place on the
    board. I have to use 2 mil grid width for routing, because 4 mil does
    not work. so this takes too much time and not all attempts are successful.
    Anyway. thanks again for your help.
    Best regards,
    Firat Kocak
    you could also manually "lead out" the power and ground pins with short
    length of 8mil before routing, then autoroute. but i don't know of any
    way to make autorouter smart enough to thin the traces as you come close
    to the pads.
  • firatkocak
    hi,
    I see. But it would be very nice to split a net into subnets and set
    each of them to a different class.
    Anyway. I will either find a way for solution or leave it as it is.
    Best regards,
    Firat Kocak
    to the pads.
