hi, thanks for clicking. i've been doing some pcb design, and would like to panelise some. i've tried the panelize.ulp, which works kind of ok, but the label alignment is off and it defeats the object of using it if i then have to manually move all of them.
i've created my own library, and all my parts have the "name" label centered on the part, whereas by default the originals i've modified are all aligned bottom-right or bottom-left.
when panelize.ulp is ran the labels are all offset as if they were still aligned as per the original parts.
i've taken a look through the ulp code, and dug through the ulp programming reference doc (ftp://ftp.cadsoft.de/eagle/userfiles/doc/ulp5120_en.pdf), but there doesn't seem to be a data member for UL_TEXT that applies to the text alignment (page 54 of doc).
i can manually edit the .brd file after running the ULP, and add text alignment to the XML, but again, that defeats the purpose of automating the process.
screen shots attached of misaligned labels (original part names in black, labels produced by panelising in cyan), and a snap of the .brd code with added alignment code which fixes the issue, but is a pain.
any help greatly appreciated.
cheers
joe
