    • Avnet Boards Community
EAGLE User Support (English) Eagle 5.5 can copy pad in package editor of a  device in use but cannot delete it
  • Subscribers 174 subscribers
  • Views 242 views
Here is my scenario
I have a library with a part in it. The device has all connections made
successfully. I realized the pad sizes were wrong. I did not disconnect
the symbol/package from the device before I started editing the package
as I only wanted to change the pad sizes not the connections or pins.
As part of my pad resizing efforts I determined I could use an extra pad
to help with the pad resizing/alignment. The editor gave no error for me
to copy an existing pad and resize/move it around.
When I was finished I went to delete the extra unconnected pad and I get
the unable to delete pad from device in use error.
Is there anything I can do with out disconnecting the entire device to
delete one pad that is not going to be used anyway?
Did I run into a bug as I certainly cannot add an additional pad with
package in use but I can copy one?
Glenn
    Seems related to my post in eagle.betatest:
    Subject: Adding/removing pads from package
    Date: Thu, 02 Apr 2009 08:49:42 +0200
    Yes, to me it appears as a bug.
    Tilmann
    autodeskguest over 16 years ago in reply to autodeskguest
    Tilmann
    Hi Yes... looks like they closed the "add" case but missed the "copy"
    case. I agree with your statement adding /deleting pads should be
    allowed as long as they are not connected.
    Glenn
  • kcadsoft
    kcadsoft over 16 years ago in reply to autodeskguest
    get the unable to delete pad from device in use error.
    Tilmann
    Changed for version 5.6.1:
      - Pads/smds can now be deleted from a package in a library, even if the
        package is in use by a device, as long as the pad/smd is not referenced
        by any pin in any device of that library.
      - The PAD and SMD commands can now add pads/smds to a package, even if that
        package is in use by a device.
    Klaus Schmidinger
    Hofmark 2                               Email:   kls@cadsoft.de
  • kcadsoft
    kcadsoft over 16 years ago in reply to kcadsoft
    Tilmann
    The same applies to pins in a symbol.
    Klaus Schmidinger
    autodeskguest over 16 years ago in reply to kcadsoft
    Klaus Schmidinger
    Thank You
    :o)
