EAGLE User Support (English) Is there a ULP to toggle between Top, Bottom and All layers?
  • Subscribers 179 subscribers
  • Views 716 views
  • bottom
  • top
  • all
  • layers
Eriond
Eriond over 10 years ago
Maybe it just me, but I prefer to design and route one side of the board at a time. Not really that strict, but when I switch from one side to the other, I'd like to only see whatever is relevant on that specific side.
Today I have to manually hide several layers when going from top to bottom, not only the Top (1), but also tPlace, tNames and  tWhatever... And when going back I have to hide Bottom (16), bPlace, bNames, bEtc... AND then enable all the top-related items i did previously hide. Really tiering! image
I don't posses the skills to write my own ULP, but maybe someone have already solved this situation?
If there is a solution to this, please let me know.
E
    Have a look at the display alias commands. You can for instance define
    an alias "Top with Silk" which you assign the layers that should be visible.
    Markus
  • Joop14
    0 Joop14 over 10 years ago
    I use some scripts to do this:
    Copy and paste the following text into a new file and name it:
    layer1.scr   <= filename
    DISPLAY 1 -2 -3 -4 -5 -16 23 -24 39 -40 41 -42;   <= file content
    layer2.scr
    DISPLAY -1 2 -3 -4 -5 -16 -23 -24 -39 -40 -41 -42;
    layer3.scr
    DISPLAY -1 -2 3 -4 -5 -16 -23 -24 -39 -40 -41 -42;
    layer4.scr
    DISPLAY -1 -2 -3 4 -5 -16 -23 -24 -39 -40 -41 -42;
    layer5.scr
    DISPLAY -1 -2 -3 -4 5 -16 -23 -24 -39 -40 -41 -42;
    layer16.scr
    DISPLAY -1 -2 -3 -4 -5 16 -23 24 -39 40 -41 42;
    layerall.scr
    DISPLAY 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 20 23 24 37 38 39 40 41 42 43 45 46 47 48 49;
    Put those files in the scr directory.
    Then you can type "scr layer1" <enter> and only layer 1 will be visible. Modify the scripts as you like.
    etc.
    Joop
  • Eriond
    0 Eriond over 10 years ago in reply to Joop14
    Thank You Joop!
    Maybe I was a too quick to assume that a ULP was necessary for this task. Acutally, I don't care how it's done, as long as it does what it's supposed to!
    /E
    Edit: I also found this link, now that I know to search for "script" rather than "ULP" image:
    http://dangerousprototypes.com/2012/07/25/how-to-eagle-shortcuts/
    Especially the comment from "Mats" really made my day!
    If you choose to assign various keyboard shortcuts and would like to use them at all places where you have Eagle installed, You need to copy the file:
    C:\Users\[User]\AppData\Roaming\CadSoft\EAGLE\eaglerc.usr to each machine.
