EAGLE User Support (English) Problem with gerber file dimensions
  • Replies 9 replies
  • Subscribers 178 subscribers
  • Views 1728 views
Hi, when I create gerber data and drill files I see the following in my
gerber viewer:
Picture link: http://www.ttalens.com/download/eagle/gerber1.JPG
I remember I have to do some settings in the window below. But I can't
remember what settings I have to do.
http://www.ttalens.com/download/eagle/gerber2.JPG
Best Regards
    gerber viewer:
    Common problem when the viewer misinterprets the file format of the
    drill data...
    For me (using SM1000 drill files) the correct settings are:
    3.2/abs/leading/mm.
    Tilmann
    if you are using the "EXCELLON" device when generating drill data with
    Eagle, you have to setup your Gerber viewer (it looks like "GC-Preview") to:
    "Whole Digits: 1"
    "Precision: 4"
    The rest is correct
    gerber viewer:
    Best Regards
    Hello Ben,
    I use Excellon to generate the drill data. While importing the drill data
    using GC-Prevue, I set the - Whole digit to 1 and Precision to 4. But I see
    that my drill hole position are offset from where they are supposed to be.
    They don't overlap with the pads in the other layers.
    Also when I import the drd file , I get the message saying " Ignoring
    information in the header ".  Is that how it is supposed to be. I am new to
    PCB design and I apologize if my questions is very amatuer.
    Thank you.
    Ashwath
    "Ben" <frank.dannull@meinberg.de> wrote in message
    news:gtu8s2$ui$1@cheetah.cadsoft.de...
    to:
    "Whole Digits: 1"
    "Precision: 4"
    The rest is correct
    gerber viewer:
    Best Regards
    Normally a drill file generated by Eagle using the Excellon device has
    no "header". So, GC Preview shouldn't recognize a header and ignore it...
    How do the first two or three lines of your *.drd file look like (you
    can use a text editor to open it) ?
    When generating the drill file: is the offset for "x" and "y" in the CAM
    processor set to "0" (zero) ?
    Ashwath Pavithran schrieb:
    Hello Ben,
    data using GC-Prevue, I set the - Whole digit to 1 and Precision to 4.
    But I see that my drill hole position are offset from where they are
    supposed to be. They don't overlap with the pads in the other layers.
    to PCB design and I apologize if my questions is very amatuer.
    Thank you.
    Ashwath
    "GC-Preview") to:
    "Whole Digits: 1"
    "Precision: 4"
    The rest is correct
    my gerber viewer:
    can't remember what settings I have to do.
    Best Regards
    Ben,
    Thank you for replying.
    These are the first few lines of the DRD file -
    M48
    M72
    T01C0.0150
    T02C0.0236
    T03C0.0360
    T04C0.0394
    T05C0.0400
    T06C0.0520
    T07C0.0551
    T08C0.0709
    T09C0.0787
    T10C0.0945
    By default, the x and y offsets where '0' and I didnt make any changes to
    them.
    Is there something I need to do before I run Excellon ? Some one, on the
    internet, had suggested running drillcfg.ulp? What does this do ?
    Ashwath
    news:gu0s2a$f5$1@cheetah.cadsoft.de...
    Normally a drill file generated by Eagle using the Excellon device has no
    How do the first two or three lines of your *.drd file look like (you can
    Hello Ben,
    see that my drill hole position are offset from where they are supposed
    Thank you.
    Ashwath
    to:
    "Whole Digits: 1"
    "Precision: 4"
    The rest is correct
    gerber viewer:
    Best Regards
    the drd file seems to be correct.
    Maybe your problem is related to the following topic: "Offset in CAM Output"
    Did you set the option "Positive coords" when generating Gerder data ?
    Ben,
    M48
    M72
    T01C0.0150
    T02C0.0236
    T03C0.0360
    T04C0.0394
    T05C0.0400
    T06C0.0520
    T07C0.0551
    T08C0.0709
    T09C0.0787
    T10C0.0945
    to them.
    Ashwath
    CAM processor set to "0" (zero) ?
    Hello Ben,
    4. But I see that my drill hole position are offset from where they
    are supposed to be. They don't overlap with the pads in the other
    layers.
    new to PCB design and I apologize if my questions is very amatuer.
    Thank you.
    Ashwath
    with Eagle, you have to setup your Gerber viewer (it looks like
    "GC-Preview") to:
    "Whole Digits: 1"
    "Precision: 4"
    The rest is correct
    in my gerber viewer:
    Best Regards
    Ben,
    " Positive coords" was set by default and i did not change it.
    Also I had another question. Mine is a 4 layered board and I use
    "gerb274x-4layer" to create the gerber files. Layer 15 and Bottom layer has
    the mirror option enabled. I assume this is how it should be.
    But when I import it to GC-Prevue, how do I import layer 15 and bottom in
    such a way so that when I overlap them all the pads align. I apologize for
    asking this question in this thread but since you are familiar with
    GC-Prevue , I thought I did ask you.
    Thank you.
    Ashwath
    news:gu8s39$rn1$1@cheetah.cadsoft.de...
    Output"
    Ben,
    M48
    M72
    T01C0.0150
    T02C0.0236
    T03C0.0360
    T04C0.0394
    T05C0.0400
    T06C0.0520
    T07C0.0551
    T08C0.0709
    T09C0.0787
    T10C0.0945
    them.
    Ashwath
    it...
    Hello Ben,
    Thank you.
    Ashwath
    "GC-Preview") to:
    "Whole Digits: 1"
    "Precision: 4"
    The rest is correct
    my gerber viewer:
    Best Regards
    Ben,
    Now I find that the Drills are aligned properly with the layers associated
    with the component layer. But there is an offset in the board edge between
    the layers associated with components side and those associated with solder
    side.
    Do we need to keep the 'mirror' option enabled for layers associated with
    the solder side ?
    Ashwath
    Output"
    Ben,
    M48
    M72
    T01C0.0150
    T02C0.0236
    T03C0.0360
    T04C0.0394
    T05C0.0400
    T06C0.0520
    T07C0.0551
    T08C0.0709
    T09C0.0787
    T10C0.0945
    them.
    Ashwath
    it...
    Hello Ben,
    Thank you.
    Ashwath
    "GC-Preview") to:
    "Whole Digits: 1"
    "Precision: 4"
    The rest is correct
    my gerber viewer:
    Best Regards
  • Richard_H
    Richard_H over 16 years ago
    Ben,
    associated with the component layer. But there is an offset in the board
    edge between the layers associated with components side and those
    associated with solder side.
    with the solder side ?
    Ashwath
    Switch off the MIRROR flags in the CAM job sections if you prefer
    to have everything displayed the same.
    The Mirror option is set on the one hand for historic reasons and
    on the other hand for all those customers that want to print on a
    foil and make their boards manually.
    For a commercial board house it's no problem to mirror the gerber
    output if needed.
    Richard Hammerl
