EAGLE User Support (English) Large plot of data warning message?
  • Subscribers 178 subscribers
  • Views 637 views
  • plot
  • polygon
  • gerber
Hi guys,
when trying to create gerber files I got this warning message:
"Signal 'GND' contains polygon that may cause extremely large plot data"
then if I try to continue it takes a lot of time to create a simple gerber.
How can I correctly set polygon plane to avoid this issue?
Thanks.
    use a line width > 0
    "Michele Bertoni"  skrev i nyhetsmeldingen:
    1209280296.181427123295400.JavaMail.jive@flcspu-csapp-01.premierfarnell.com
    The explanation is that eagle fills this using wire fill with the width
    specified with the polygon. If with is 0, eagle will use a minimum value
    wich is very small and generate an enormous number of lines.
