EAGLE User Support (English) Forcing grid / angle alignment
  • Subscribers 183 subscribers
  • Views 1560 views
When I'm moving a PCB trace (which had previously been moved off the primary
grid), what is the simplest way to tell Eagle "put this trace back on the
primary grid"? Another time I've wanted to do this is when I ended up
needing to change to more aggressive design rules, and switched from a
10-mil primary grid to a 7-mil grid--new traces worked great, but squeezing
the existing ones closer together was a major nuisance.
Similarly, when moving a trace, what is the easiest way to tell Eagle "make
this trace exactly 90 (or 45) degree aligned"?
If there isn't an easy keystroke/mouse combo already defined, is there some
command sequence I could bind to a key?
    "Olin Sibert" <eagle@olinsibert.com> a écrit dans le message de news:
    guhfpl$dph$1@cheetah.cadsoft.de...
    primary grid), what is the simplest way to tell Eagle "put this trace back
    on the primary grid"? Another time I've wanted to do this is when I ended
    up needing to change to more aggressive design rules, and switched from a
    squeezing the existing ones closer together was a major nuisance.
    Ctrl MOVE: move and snap the element on the current grid.
    "make this trace exactly 90 (or 45) degree aligned"?
    SPLIT: break the wire in segments, you can choose the angle with the right
    button of the mouse.
    some command sequence I could bind to a key?
    Have a look for the "Help"
    "Christian Bohrer" <cbo@tele2.fr> wrote in message
    news:guhrsu$3kh$1@cheetah.cadsoft.de...
    back on the primary grid"? Another time I've wanted to do this is when I
    ended up needing to change to more aggressive design rules, and switched
    from a 10-mil primary grid to a 7-mil grid--new traces worked great, but
    Thank you. I overlooked that one in the help.
    SPLIT isn't quite what I want to do here, because even though the trace
    I've split ends up with nice alignment, after that, I have to fix up the
    rest
    of what it's connected to by hand.
    For example, what I'd like to do is move a corner (or a via) and tell
    Eagle "keep everything connected here fit to the nearest 45-degree
    angle", and have it make corresponding adjustments at the segments
    they are connected to. I can do this all with SPLIT, but I'm trying to
    reduce the amount of manual adjustment I need to do afterward.
    Or maybe I'm just not using SPLIT correctly. That's quite possible,
    since it still doesn't feel particularly natiural, and I'm never quite sure
    what it will do.
    i delete or unroute the old trace and lay a new one using the 45 angle
    wire setting. yup, that's not much help either!
    rest
    what it will do.
    Get more used to EAGLE. image
    It depends on where you pick the wire segment.
    For MOVE, each segment is divided into three parts. If you pick the
    inner third, you move the complete segment. Picking the outer thirds
    will let you move the endpoints (including attached vias and/or
    neighbour segments).
    For SPLIT, each segment is divided in two parts. The wire bend mode is
    applied to the smaller part of the segment, you continue modifying the
    track in direction of the longer part.
    Play with these commands to get used to them. Once you are, they are
    very powerful and perfectly predictable.
    (I have assigned ROUTE, MOVE and SPLIT on function keys which makes
    using them very fast.)
    Tilmann
