EAGLE User Support (English) Problem with Eagle displaying the 'Add' dialog under Linux Window Manager (OLVWM)
  • Subscribers 179 subscribers
  • Views 295 views
When I hit 'Esc' after adding a part to Schematic Editor, I do not get the 'Add' dialog.
Eagle is doing some kind of check of Linux window managers and not generating a MapNotify, Reparent when it is run under OLVWM. I can manually do xdotool windowmap 0x280004f and force that hidden window to display correctly.
Eagle: Editing a faulty part in 7.2 - how? - Electrical Engineering Stack Exchange and Eagle 7.2.0: "Esc" after "Add" does nothing (I don't get back the Add dialog)
Perhaps there is a if statement in your code that checks all popular Linux WMs and does one thing and then if OLVWM doesn't match that list, you handle it in some other way.. Could you please fix or add my OLVWM window manager to your list of supported Linux Window Managers.
  • element14support
    0 element14support over 10 years ago
    Hello veek
    Welcome to the element14 Community, I will over this over to the EAGLE Support area as it is a better fit.
    Thank you,
    Jamie
  • Joop14
    0 Joop14 over 10 years ago
    Eagle uses Qt (http://www.qt.io/) for the graphical interface (menus, boxes, etc.). Imho, there's almost nothing that can be done about this except for changing your desktop to something more common, e.g. KDE, LXDE, XFCE or Gnome .
