EAGLE User Support (English) Layer 2 (GND) used but not enabled!
  • Subscribers 187 subscribers
  • Views 1115 views
Dialog with the following message is presented during autoroute.
Objects therein may collide with vias placed by the autorouter.
Do you wish to run the autorouter anyway?
Layer 2 was initially a supply layer. However, the layer has been changed to
a normal layer and a polygon placed on layer 2. The polygon is named GND
and is visible, but the autorouter will not place vias down and connect to
the polygon. How do I enable the layer. I'm unable to change back to a
supply layer as there are a couple of signals routed on the layer.
Jim
    Yep. Supply layer changes layer to N/A I suppose. The change back to signal
    layer doesn't revert that setting. Should have seen that one.
    Jim
    "Richard Hammerl" <ric@cadsoft.de> wrote in message
    news:gutocm$si5$1@cheetah.cadsoft.de...
    Please check the settings in the General tab of the Autorouter
    Setup window. I suppose layer 2 is set to N/A.
    changed to a normal layer and a polygon placed on layer 2. The polygon
    is named GND and is visible, but the autorouter will not place vias down
    and connect to the polygon. How do I enable the layer. I'm unable to
    change back to a supply layer as there are a couple of signals routed on
    the layer.
    Jim
    Richard Hammerl
  • Richard_H
    Richard_H over 17 years ago
    the layer.
    Jim
    Richard Hammerl
