EAGLE User Support (English) Lite Version blockage
  • Replies 10 replies
  • Subscribers 179 subscribers
  • Views 678 views
thommaughan
thommaughan over 16 years ago
I'm new to Eagle (from Protel, Orcad background).
I've got the Free 'lite' version installed and have drawn a simple schematic
(555 timer with a few resistors and capacitors).
I'm blocked trying to layout the Board.   The footprints are on the board in
the lower right corner.    When I try to move the footprints I get the error
message:
"The Light edition of EAGLE can't perform the requested action!  See Help
for further details.
The Help mentions nothing.
I've tried shrinking the board outline and moving it down to the bottom -
nothing works.    At this point I would not want to throw money at Eagle
since I'm still evaluating it.
Does anyone know if Eagle Light is limited (or broken) for board layout?
Thom
    Former Member over 16 years ago
    the limit is 80x100mm (1/2 euro card). Moving outside that area is not
    possible.
    r
  • thommaughan
    80x100mm is about 3.1x3.9".
    The Eagle coordinate display is a bit odd, it shows 0,0 in the upper right
    and -2.50 x -3.80 in the lower.   If I size the board outline, does this
    size the board or is there a buried property that sizes the board???
    The Eagle help does not offer much help.   I've given up on the help system
    and am using google for the most part to resolve the usability issues
    encountered so far.  Here's what you get when you search board size in Eagle
    Help:
    Board Size
    The Autorouter puts a rectangle around all objects in the board and takes
    the size of this rectangle as the routing area. Wires in the Dimension layer
    are border lines for the Autorouter. This means you can delimit the route
    area with closed lines drawn into this layer with the WIRE command.
    In practice you draw the board outlines into the Dimension layer with the
    WIRE command and place the components within this area.
    "Ing. J.M. Rafetseder" <jrafetseder@hotmail.com> wrote in message
    news:guue0q$a4r$1@cheetah.cadsoft.de...
    possible.
    r
    You are only allowed to use the positive coordinates in the lite edition.
    The board outlines in the dimension layer affects the autorouter and the
    DRC as far as I know.
    Alexander Horst
    What to do in making a board with the Lite version of EAGLE:
    Open the board from your schematic. Delete any existing dimension wires
    (the default ones EAGLE draws to show boundaries), then type this command:
    change layer dimension; change width 0; grid mm; wire (0 0) (80 0); wire
    (80 0) (80 100); wire (80 100) (0 100); wire (0 100) (0 0);
    These are your dimensions for a board layout in EAGLE Lite. You may draw
    wires outside these boundaries, but no components may lie outside. From
    here, you can chose the move tool and get all of your parts inside this
    rectangle. From there, place your parts as you wish, then route using
    Autoroute or Route commands.- ted
    ted@markson.us
    Help:
    Board Size
    possible.
    r
    On Tue, 19 May 2009, Thom Maughan wrote to us saying :
    message:
    When you add a component to the schematic, Eagle places its package on
    the board at negative coordinates. This is explicitly BECAUSE that's not
    part of the board - when you add new parts to a circuit you've already
    started to lay out, you really don't want them dumped on top of the
    existing circuitry.
    When you create the board from the schematic, Eagle draws two things on
    it :
       -  An outline in the Dimension layer, which shows the allowed board
    area
       -  The components from the schematic
    So, if you proceed the normal way, as you have, of drawing your whole
    first draft schematic then hitting the "board" button, what you get is a
    load of parts and a white box. The parts are all outside the box. You
    are allowed to move the parts BUT you MUST place them INSIDE the box.
    (You can also adjust the outline by moving corners or sides, or adding
    corners, or deleting the whole thing and drawing it again. Somebody else
    recommended this as a first step - I disagree. Until you're confident I
    would recommend leaving the outline as it is until you've placed all
    your parts to your satisfaction. If you explicitly KNOW what size your
    board must be then by all means draw the outline first, but if you're
    just playing then the default outline is useful to show where you are
    allowed to put things.)
    Rob Pearce                       http://www.bdt-home.demon.co.uk
    The contents of this | Windows NT crashed.
    message are purely   | I am the Blue Screen of Death.
    my opinion. Don't    | No one hears your screams.
    believe a word.      |
    The default outline holds negative coordinates; instead of placing the
    left-most and bottom-most extents at their respective 0.0 position,
    these are placed at negative values. When using EAGLE Lite, this can be
    confusing for some users as they might think these negative extents are
    acceptable when doing layout. This is why I recommend redrawing the
    dimension boundary, to eliminate any confusion.- ted
    ted@markson.us
    board in
    error
    message:
    existing circuitry.
    it :
      -  An outline in the Dimension layer, which shows the allowed board area
    that's no longer the case since 5.x
    Lorenz
    http://lumisense.com/eagle.png
    .- ted
    ted@markson.us
    On Wed, 20 May 2009, Lorenz wrote to us saying :
    And even on 4.15 it was less-negative-than-the-grid-pitch by default,
    making it moderately hard to place a component inside the border but at
    illegal position. For a newbie, the rule of thumb I gave applies.
    believe a word.      |
    .- ted
    ted@markson.us
    a well, I checked with 5.4.0o the change must have occured after 5.0.0
    Lorenz
