EAGLE User Support (English) hole shape and size
  • Subscribers 177 subscribers
  • Views 195 views
hole shape and size
Is there a way to make a rectangluar hole?
I also found out that EAGLE have a max drill size of hole, 33.1mm. I have to
create a circle in the documentation layer and notify board house as a hole
when I need a 33.5mm hole. Does anyone have a better way?
    To create a rectangular hole, you may create a shape on either the
    Dimension or Milling layers.
    Same goes for a hole larger than the limit - create a circle shape on
    either Dimension or Milling layers.
    Whichever layer you chose in either case, be sure it is exported in
    gerber. It's always good to leave comments with your board when given to
    a fab house - the more they know, the less chance of a
    misunderstanding!- ted
    ted@markson.us
