EAGLE User Support (English) through hole wirepad on only one side of PCB
  • Views 1833 views
I need to route multiple traces between through hole wirepads which I in turn need to be able to manually solder too, however the wirepads in the default library use the 'Pad' layer which does not have a specific side of my (two layer) PCB.  From what I can gather via google, it seems that pads are assumed to be on both sides of the PCB, however if I have an exposed pad on both sides there won't be enough space for my traces.  Is there any way to make a hole for a component to go through with only a pad on one side?  Would just putting a hole there and then drawing a circle on my top layer work?
    Am 15.04.2015 um 00:18 schrieb Chris Boland:
    There may be a more 'official' way but you can create your own pad. I
    have a library called custom.lbr, in there I would, in your case, use an
    SMD pad, change layer to bottom (I assume you want it on the bottom)
    then add a hole through it. Save it and use it in your design.
    A HOLE inside a SMD ghenerate a DRC-Error?
    Use a PAD change the Diameter to the Drill-Diameter,
    place a POLYGON at the layer around the PAD and set
    the Restring-Parameter at the Design-Rules at
    Min. = 0 and percent % = 0 image
    Alfred Zaffran
                                 Web:   <www.cadsoft.de>
    Geschaeftsfuehrer: Mark Whiteling
    cool, that's about what I surmised
    There may be a more 'official' way but you can create your own pad. I have a library called custom.lbr, in there I would, in your case, use an SMD pad, change layer to bottom (I assume you want it on the bottom) then add a hole through it. Save it and use it in your design.
