EAGLE User Support (English) no connect symbol
  • Subscribers 187 subscribers
  • Views 1285 views
no connect symbol
Is there a symbol/part for 'no connect'?
Some pins may or may not need to be connected on some parts and I'd like
EAGLE to recognise that I do not wish them to be connected.
Kind regards,
Jerome
    You may change the symbol direction to NC . When a DRC is run, if any
    net is connected to an NC pin, it will return an error.
    In the library, use the command: CHANGE DIRECTION NC
    Click to use the tool on each net.- ted
    ted@markson.us
    Kind regards,
    Jerome
    On Fri, 22 May 2009 16:36:47 +0100, Jerome Oswald-Jones
    Kind regards,
    Jerome
    AFAIK, if a pin is not input only, EAGLE shouldn't complain when it is not
    connected.  I created an "X" symbol that I place near an unused pin to
    remind myself that I don't want to connect to the pin.  I don't connect a
    net to that pin.
    -Dave Pollum
