EAGLE User Support (English) wire communication between 2 arduinos
  • Subscribers 182 subscribers
  • Views 472 views
i am having issues getting my code to display the reading from the sensors on the lcd which is located on the second arduino
this is the code that i wrote for it and any help would be great in getting it to work.
//reciever
#include <SPI.h>
#include <LiquidCrystal.h>
int heartratepin=A1;
int inpin=A0;
LiquidCrystal lcd(30,31,32,33,34,35);
void setup()
  lcd.begin(16,2);
  Serial.begin(9600);
void loop()
  if(Serial.available()==1)
    int inByte=Serial.read();
    int analogValue=analogRead(inpin);
    lcd.print(analogValue);
    lcd.print(",");
    int newHeartReading=analogRead(heartratepin);
    lcd.print(newHeartReading);
    lcd.print(",");
//sender
int inpin=A0;
int TEMP=0;
int difference;
int newHeartReading = 0;
int lastHeartReading = 0;
int measurements[5] = {0,0,0,0,0};
int historySize = 5;
int recenttotal = 0;
int Index = 0;
boolean highChange = false;
int minimumdifference = 2;
int num[5];
int average=0;
// Heart rate timing
long lastHeartbeatTime = 0;
long debounceDelay = 150;       // the debounce time; increase if the output flickers
int currentHeartrate = 0;
int lastHeartrate = 0;
//Heart rate LED
int ledState = LOW;
long ledOnMillis = 0;
long ledOnInterval = 50;
int slope = ((newHeartReading-lastHeartReading)/(debounceDelay-lastHeartrate));
// Debugging string
String debugOutput = "";
void setup() {
   // start serial port at 9600 bps:
   Serial.begin(9600);
   // pinMode(heartratepin,INPUT);
   establishContact();
void establishContact() {
while (Serial.available() <= 0) {
      Serial.println("hello");   // send a starting message
      delay(300);
void loop() {
   int analogValue = analogRead(inpin);
   float millivolts = (analogValue/1024.0)*5000;
   float celsius = millivolts/10-50;
   Serial.println(analogValue);
   Serial.print(celsius);
   Serial.print("c");
   Serial.print((celsius*9)/5+32);
   Serial.print("F");
   newHeartReading = analogRead(heartratepin);
    //calculation
  difference = newHeartReading - lastHeartReading;
  lastHeartReading = newHeartReading;
  // Find new recent total
  recenttotal = recenttotal - measurements[Index] + difference;
  // replace indexed recent value
  measurements[Index] = difference;
   //index + 1 index = (index + 1) % historySize;
    for (int i=0; i<5; i=i+1){
               num[i]=0;
              if (Index>=5)
              Index=0;
              //calculating the average
              average=recenttotal/5;
              Serial.println(average);
              delay(10);
  if (recenttotal >= minimumdifference)
    // possible heart rate check timing
    if (millis() - lastHeartbeatTime >= debounceDelay)   // whatever the reading is at, it's been there for longer
    // than the debounce delay, so take it as the actual current state:
  // Heart rate
  //digitalWrite(ledPin, HIGH);
  currentHeartrate = 60000 / (millis() - lastHeartbeatTime);
    lastHeartbeatTime = millis();
   Serial.println(newHeartReading);
      if (currentHeartrate <= 200)// && currentHeartrate > 20)
                  Serial.print("Heart Rate =" + String(currentHeartrate) + "  ");
                  delay(10);
            if (currentHeartrate <= 39 and currentHeartrate >= 0){
                  Serial.print("I Am Sick");
                 delay(10);
          if (currentHeartrate<= 79 and currentHeartrate >= 70){
                  Serial.print("Night Mare");
                delay(10);
            if (currentHeartrate <= 69 and currentHeartrate >= 40){
                  Serial.print("kid Is At Sleep");
              delay(10);
              if (currentHeartrate <= 99 and currentHeartrate >= 80){
                  Serial.print("Kid Is Resting");
                delay(10);
                if (currentHeartrate <= 119 and currentHeartrate >= 100){
                  Serial.print("Kid Is Playing");
                  if(currentHeartrate > 120){
                    Serial.print(" The Kid Is Having ");
                    Serial.print(" A Heart Attack");
   // print different formats:
   Serial.write(analogValue);  // Print the raw binary value
   Serial.print('\t');             // print a tab
   Serial.write(newHeartReading);  // Print the raw binary value
  • clem57
    0 clem57 over 10 years ago
    For help, please move this to The specified item was not found. where this will be seen by the right people.
  • gadget.iom
    0 gadget.iom over 10 years ago
    In your receiver code you have the following line:
    which is taking the input characters from the serial string. The issue is that you don't appear to be using "inByte" anywhere else in that code.
    You appear to reading and displaying analog values locally on the receiver instead.
    Try replacing all of the LCD print institutions with a single line:
    lcd.print(inByte);
    Your new code on the receiver should be something like:
    // Reciever
    #include <SPI.h>
    void setup() {
      lcd.begin(16,2);
      Serial.begin(9600);
    void loop() {
      if(Serial.available()==1) {
        lcd.print(inByte);
    See how you get on with that.
    0 Former Member over 10 years ago in reply to gadget.iom
    it didnt work
