EAGLE User Support (English) How do I make a part in the part editor where the text i add (numbering of pins) is ''smashable''?
  • Views 365 views
  • clem57
    0 clem57 over 11 years ago
    Do you want this:
    http://www.electro-tech-online.com/attachments/net-label-png.49579/
    Connect the net to the pin you want and end it a little ways out. Name it (name tool) and label it (label tool). Then start your net somewhere else. Name it the same and label it as well. Labeling just puts the text above the net line so it's not confusing.
    In the attached example I have named and labeled a net called TX which goes from one IC to another, but the green line doesn't physically connect them.
    I usually avoid this myself out of personally preference. I like to just trace the lines wherever they go.
    Clem
